Blinker Lights
Old Nov 26, 2018 | 08:04 AM
JRT812's Avatar
JRT812
Blinker Lights
78 F150... a fuse blew a week ago and has been replaced. Blinkers worked for a week and now don’t. There has been no issues up to now. Bulbs look good and all other lights work other than hazards work. I checked the grounds at each socket. Is there any other grounds that I’m potentially missing?
Old Nov 26, 2018 | 09:59 AM
meangreen92's Avatar
meangreen92
The ground from your engine to the cab.
Also check the fuse box contacts to make sure that there's no corrosion impeding the current.
Old Nov 26, 2018 | 12:27 PM
JRT812's Avatar
JRT812
Thank you!
Old Nov 26, 2018 | 12:46 PM
Mason R's Avatar
Mason R
Check your flasher, it could be bad or it might not have power going to it which could be the turn signal switch
Old Nov 26, 2018 | 03:48 PM
mark a.'s Avatar
mark a.
Did you try a known good flasher ? Did you take the flasher out and check for power ? If you have power there, then make up a wire to jump it over and see if all the lights that flash come on. If they do then your turn signal switch is probably bad.
Old Nov 26, 2018 | 03:58 PM
JRT812's Avatar
JRT812
Thanks for all the help! Even though I recently changed the flashers that ended up being the problem... I guess. Changed them again with HD ones after checking wiring and grounds. Hopefully this isn’t a sign of electrical gremlins. The flashers are just from the local ORiley
Jackpot11
Mar 8, 2015 08:03 PM
buckeyeinatl
17
Oct 12, 2014 10:27 PM
The Terrible Blob
Sep 24, 2013 07:05 PM
Ferrariferg
Jul 30, 2012 06:39 PM
onion
May 7, 2005 10:46 PM
