Short bed with wide body 5th wheel?
Old 11-26-2018, 07:35 PM
7591250sd's Avatar
7591250sd
7591250sd is offline
I have a 2018 F250 CCSB, with the BW Patriot ( non slider ) my 5ver has a recessed cap. With hitch in most rear position, plenty of turning room.
The BW hitches have several inch's of forward/aft adjustment, as well as height.
Old 11-26-2018, 08:04 PM
ShadowGrey's Avatar
ShadowGrey
ShadowGrey is offline
Some have to turn it the other way around to have enough clearance for the pin box sticking down to clear the bed rails when turning. The factory GN ball is over the rear axle. The AUH ball is 9" back and the coupler can be turned either way to give you extra clearance for the cab or turned around to give you extra clearance for the bed rails...depends on the truck bed length and the height of the bed rails relative to the pin box sticking down when running the trailer level. Need 6-8" of bed rail clearance but with the truck beds being so deep now days that is hard to do and still keep the trailer from running nose high.
Old 11-26-2018, 09:25 PM
Army RET's Avatar
Army RET
Army RET is offline
Don't overlook the ball mounted on TOP of the AUH, it is adjustable up/down, as seen in the above picture.
And while I may be wrong I don't believe the connecting point is 9" behind the goose ball; regardless of where it physically is the weight is distributed to the bed hitch.
Old 11-29-2018, 08:11 PM
Jim Houchin's Avatar
Jim Houchin
Jim Houchin is offline
Lightbulb
Originally Posted by ShadowGrey
Anybody tow a wide body (102" wide) 5th wheel with a short bed, 2017 or up? What hitch are you using? Debating an Demco auto slider or an Anderson Hitch...
From what I see below... If you have a the Ford SRW CCSB 6.7 you don't need to worry about which hitch to use as you'll be overweight as soon as you pull the legs out from under that 5ver! What a MONSTER rig, love Jayco. I think there's only one SRW that can legally tow that beast and that's the Ram 3500, It's got the *up to 12,300 GVWR (cheaters) means you could have up to 4300 lbs of payload with the diesel engine along with a 25,300 GCWR.
Either way Happy Hunting! .... yes I always wanted to play internet weight policeman!
2018 Ram 3500 Specs
CREWCAB LONG BOX, 4X4, SRW
6.7L CUMMINS DIESEL (HO) 12,300 4,320 25,300
CREWCAB SHORT BOX, 4X4, SRW
6.7L CUMMINS DIESEL (HO) 11,500 4,000 25,300
2019 Jayco Pinnacle 36FBTS Specs...
I know, I know... it's an Eagle! BUT... pin is 2100 AND it's got the large bathroom. (No I'm not a salesman... I'm the police remember.)
Old 11-29-2018, 09:12 PM
ShadowGrey's Avatar
ShadowGrey
Thanks for the info Jim, I sure will take that into consideration...popo.
Old 11-30-2018, 07:42 AM
SkiSmuggs's Avatar
SkiSmuggs
SkiSmuggs is offline
I believe the Pinnacle will have a short pin box, so you should put the adapter socket in front of the pin.
Old 11-30-2018, 09:05 AM
Jim Houchin
Talking
Mr. Grey sir you are a gentleman and a scholar and there are damn few of us left! I use the spreadsheet (that I stole off an rv forum) to play with the numbers. If you get some numbers off of the truck and the rv you can really see what you're working with as far as payload and carry weight. For me my problem isn't payload OR tow weight. I have 4000lbs payload and 15,000lbs of 5th wheel carry, BUT since I've got a gasser, my max GCWR is 22,000lbs. So if my truck weights 8500lbs loaded up (I'll have 2500lbs left for my pin), But then my 5th wheel can't weight over 13,500lbs. for every pound over 7000lbs (my GVRW is 11,000lbs), I loose that pound off the my towing capability. That won't be your issue with the calculation. Your issue will be payload, and the beauty of the spreadsheet is that it uses the carry/cargo/pin weight together. I think you can use it along with the hitch weights your considering to figure out if you can hand the weight of a roller... or if you'll need an extended pin box and the Andersen. I left my current numbers in the sheet, enjoy!
Last thought Reese gooseBox Pin? Zero hitch weight! But not sure on a short bed?
File Type: xlsx
Old 12-01-2018, 08:59 AM
Desert Don's Avatar
Desert Don
Desert Don is offline
Received 4,741 Likes on 1,680 Posts
Well, these specs are real close to what my Raptor’s are. I started pulling it with a CCSB SRW equipped with B&W turnover ball and companion hitch. I had the hitch set up so the trailer was as far back as possible, and YES, the 102” wide body would definitely hit when turning too tight.......ask me how I know.I was lucky and only marred the paint a bit. And no, mine truck was not a ‘17+; it was an ‘11.
And before you go any further with this, I would advise to, if there is ANY way possibe, to get the rig weighed to get the ACTUAL weights before buying!!
Ask me how I know this, also. The “dry” weight listed likely does not include batteries, generator, propane bottles, etc. Then when you add your gear, the pin weight could very easily be close to 1000 lb more than this listed weight. My first long trip with the SRW, I smoked a set of rear tires in 3000 miles. All this weight stuff is just FYI. I see people pulling big 5ers with SRW’s all the time.
Old 12-04-2018, 06:31 PM
slapshot12's Avatar
slapshot12
slapshot12 is offline
Looks close what we are going to tow. Couple of questions if you don't mind...Do you know how much room you have between the cab and cap while turning? Do you have the connection coupler turned towards the front like "normal" or turned around to give you extra clearance of the pin box to bed rail?
I can turn about 80* give or take, which is plenty. Those super sharp turns are very hard on the trailer suspension components. My coupler is reversed since I have a short bed. That gives the most bed rail clearance. Reversed is recommended for short beds by Andersen.
Old 12-05-2018, 12:31 AM
Beast2017's Avatar
Beast2017
Beast2017 is offline
2017+ srw short bed trucks have an extra 3/4 foot in the bed between the back of the cab and the rear axle for what it’s worth I’ve never needed to engage my slider .. in two years many trips .. wish I’d spent the extra money on a lighter hitch instead I have a 26k husky with manual slide
fatherof7
Fifth Wheel & Gooseneck RV Towing
17
02-21-2019 09:01 AM
intofire56A
2015 - 2020 F150
13
09-13-2018 12:24 PM
f350ktm
2017+ Super Duty
15
02-26-2018 12:20 AM
johns10
1999 to 2016 Super Duty
16
06-11-2007 12:51 PM
SD10
11-13-1999 02:24 PM
Quick Reply: Short bed with wide body 5th wheel?
