TOWING WITH 5TH WHEEL - 5 1/2' BED
Has any towed or is towing a 5th wheel with a 5 1/2' bed? I have watched videos of the Reese Sidewinder using a short bed F150? Need actual testimony from users like you. Does it work on all 5th wheels?
I have noticed that the newer 5th wheel or some manufacturers are tampering the front ends of the trailer, not sure for looks or it actually gives more room to turn with sliding hitch on 6 1/2' beds..??
I am also wondering if the trailer is new, the application of the Sidewinder would void any warranty.
my research started as we looked at travel trailers, that what we want is pushing 30',
Thanks, Rick
Thanks, Rick
Wow, nice rig...can you send close up pictures of the hitch configuration and type and brand, trailers PIN weight, do have standard tow pkg or max? Can the tailgate drop in that position
Nice rig! Can you tell me what your towing capacity is? I'm interested in a 5th wheel for half tons, and own a 2017 F150 with a 5.0 standard tow package.
The tailgate will drop, clearance is minimal though! I have a standard tow package so yes I am overloaded by the factory rating. However I added 3.92 gears, air bags with onboard compressor and a rear sway bar. The 5er weighs in at 9100 dry so I figure I'm around 10k loaded. No issues pulling though but obviously the truck is still overloaded by the manufacture suggested sticker... I don't have a clear close up picture of the hitch but you may be able to make it out with this one. Adjustable Pinbox and gooseneck adapter.
I was originally going to tow a 5er with my 2.7/ 5.5 box so I bought air bags and sidewinder, after thinking some more about it I decided I would get the 3.5 just to make sure i have the power to tow my new 5er. I also made the choice while getting the new truck I would also get the 6.5 box , after towing for this past season I have come to the conclusion that the sidewinder would have worked fine with the 5.5 box no issues but although the 2.7 is a fantastic engine the extra torque in the 3.5 is needed. I have also just recently taken off the sidewinder and use the factory pin box with no clearance issues. I am towing a 34' 5er loaded at 9500#
Again my concern is eventhough the hitch is over the axle, is it a known fact that weight of trailer is all on that hitch, or is there weight on the extended piece (Sidewinder) between the hitch and trailer connection (that bridge area, the cantilever area)...changing the weight over the bed behind the axle. Which changes the stress on the truck and swaying,
Does the front of the trailer design have any bearing when using the Sidewinder that would prevent 90° turns
ok, so you did use the Sidewinder configuration, you had no issues or concerns to it's workings or design? Did it ride differently, what hitch where you using with it?
I am using it with a b&w patriot 16k hitch currently sitting 2" ahead but that hitch can be set back up to 4".
The thing that I am currently trying to figure out is if the sidewinder is the cause of my front end bounce, I have taken off the sidewinder and have towed once with factory pin and bounce is noticeably not there
I actually did not use it with my 5.5' box as mentioned but with my 6.5' and how far it sits back there would have been no issues with the smaller box ,myv5er had the nose cap made for short beds
