300 prob
Old Sep 26, 2003 | 11:12 PM
pyropig's Avatar
pyropig
300 prob
Well i have a f-150 with an efi 300. the problem is it runs rich when it throttles down. It shoots black smoke and unburned fuel from the tailpipe, it gets horrid gas milage, and runs like crap overall. I just replaced the o2 sensor, and it still shoots unburned fuell and black smoke out the tailpipe, it runs better i think,but its my uncles truck and i need to get it fixed for him. What else could cause the engine to run like this? I was thnking the injecters are bad and just dumping fuel in when i let off the gas. But other than that im drawing a blank.
Old Sep 28, 2003 | 11:15 PM
NM5K's Avatar
NM5K
Have you tried pulling any codes from the puter? It almost sounds like it isn't working.... Could be a number of things. A bad temp sensor could cause it to run rich when warm. Are you going into closed loop? Sounds like it's running in the base warmup mode. "open loop". Kind of one of those, gotta see it deals...MK
Old Sep 29, 2003 | 12:53 AM
bigbadjs's Avatar
bigbadjs
What year?
So the symptom is misfiring on decellaration .
This sounds like a dashpot problem on the older carb models. The Throttle position sensor replaces the function of the dashpot on fuel injected models. You can check it with a digital voltmeter. With the ignition key on just move the throttle through its range and observe any voltage drops that would indicate a malfunction. The engine will tend to run rough at specific throttle points. Thats the telltale sign of a TPS gone bad.
Early Ford throttle position sensors were troublesome.
Old Sep 29, 2003 | 04:23 PM
pyropig's Avatar
pyropig
Its a 89, i havent put it on the scan tool yet but i am working on getting one from my autos teacher. Would a Scan tool tell me if the tps is bad? or would have have to run the voltmeter on it?
Old Sep 29, 2003 | 04:29 PM
mantta's Avatar
mantta
A scan tool will give you codes for the throttle position sensor.
Old Sep 30, 2003 | 01:41 PM
Derek83's Avatar
Derek83
if no codes come up may check fuel pump pressure fuel regulator, should be right on the fuel rail.
Excurvelle
Oct 14, 2014 07:48 PM
oneowner83
17
Sep 24, 2013 01:45 PM
chasingmytail
21
Jun 9, 2008 04:25 PM
nibiru
May 25, 2004 10:34 PM
GotLift
1978 - 1996 Big Bronco
Mar 6, 2004 10:35 PM
