Lithium RV battery need help
Old Nov 25, 2018 | 10:53 AM
Rockinfigs's Avatar
Rockinfigs
I just purchased a 2020 attitude 3218mm toy hauler.. it comes w one 100amp lithium battery..the sales guy told me one lithium battery is like running two 6 volts...there is an option to add one more 100amp lithium battery and i want it but was wondering if it will be overkill for what I do....I don't full time..I go beach and desert camping about 6-8times a yr at about 4-5day avg.
Old Dec 5, 2018 | 08:25 PM
rdinmv's Avatar
rdinmv
That is quite a battery to come stock, yes you can run two in parallel, i'm actually looking into adding a 2nd aux bank of 2 Lion batts my self as I now have a residential fridge in mine just for extra capacity. What brand did they put in your trailer? they are expensive but in my mind worth it because of the amount of times you can charge them and you can run them down almost all the way without damage.
Old Dec 5, 2018 | 09:03 PM
Rockinfigs's Avatar
Rockinfigs
Yeah its new for the attitude toy hauler line for 2020..I comes with one 100 amp lithium and one 210 watt solar panel. To be honest i have no idea what brand..but i had an option to get a 2nd batt for $1000 but passed on it..maybe il add it later after few camping trips and discover i need it.
Old Dec 5, 2018 | 09:11 PM
ford390gashog's Avatar
ford390gashog
I upgraded mine to 3 of the battle born 100ah batteries. When I did it my local battery distributor gave me a promo and I paid 599.99 each. They are still new so check around for a deal.
Old Dec 6, 2018 | 05:34 AM
scraprat's Avatar
scraprat
Top Answer: 5
Look and see which manufacturer of dropin lfp battery you have. What charger do you have? What is the pt controller set at to charge your battery? Can you disconnect the solar while it's stored? Can you read the soc of the battery, or does it have a bluetooth to see it on your phone?
LFP batteries should not sit at 100% (float) when not in use it for long periods, they are happiest at 40-50% soc, the day before you go charge it. Depending on the charger size it will take no time at all. LFP is the cats meow once you understand them.
phatboy7
Jan 26, 2014 06:53 AM
MDSuperDuty
Jan 11, 2011 07:50 AM
pepito113
2004 - 2008 F150
Mar 25, 2009 06:34 PM
tjcnok
Electrical Systems/Wiring
Oct 1, 2008 08:10 PM
jimbo beam
16
Dec 31, 2006 07:35 AM
