Headache rack wiring
Old Nov 24, 2018 | 09:00 PM
OBSTommy17's Avatar
OBSTommy17
hello I have a 1989 F350 xlt lariat crew cab 7.3 idi
and I recently purchased a headache rack but I realized I did not know how to wire the lights on the rack to the truck, can someone give me some help
Old Nov 25, 2018 | 01:24 AM
BS51993's Avatar
BS51993
Did the rack come with a connector or just straight wiring? Do you have a picture to share to help with reference?
Old Nov 25, 2018 | 02:58 AM
OBSTommy17's Avatar
OBSTommy17
Old Nov 25, 2018 | 02:59 AM
OBSTommy17's Avatar
OBSTommy17
just cane with wires to splice
Old Nov 25, 2018 | 06:39 AM
Diesel_Brad's Avatar
Diesel_Brad
I usually go straight down between the bed and the cab. The T into the harness there with another short pice of harness and a plug. That way if the headache rack needs to be removed, they can simply unplug it
Old Nov 25, 2018 | 08:18 PM
OBSTommy17's Avatar
OBSTommy17
so there is a place for a plug down on the wiring harness that runs down the frame to the rear of the truck?i didn’t see anything of that sort
Old Nov 26, 2018 | 03:05 AM
Diesel_Brad
No, you need to T(splice) into the wiring
Old Nov 26, 2018 | 01:36 PM
95fiveoh's Avatar
95fiveoh
As for the wiring, the white is ground, the brown is for the running lights, the green is for the left turn signal/brake light and the yellow is for the right turn signal/brake light. Not sure what the blue is, I'm guessing power for the spotlights?
Now if it was my truck, I would do like Brad said and solder a 4 pin connector to the end of your headache rack wiring and solder the other end of the connector into a splice where the wires run through the frame rails. That way you can just plug it in.
But if you aren't experienced with soldering or wiring, you could just use Scotchlok connectors, though a lot of people would probably consider it ghetto.
Old Nov 28, 2018 | 04:17 PM
Diesel_Brad
Actually green is Right, Yellow is left.
And yes scotch locks are ghetto and allow moisture into the electrical system
Lilvixn
Feb 21, 2019 03:52 AM
ACK3000
Oct 14, 2018 09:15 AM
Dennis-
Jun 30, 2018 03:26 AM
DougJ_1997PSD
Aug 17, 2017 02:42 PM
mikey350
6.7L Power Stroke Diesel
27
Apr 16, 2013 07:59 AM
