Locating brake line???
Old Sep 26, 2003 | 10:31 PM
sixfanmatt's Avatar
sixfanmatt
Question Locating brake line???
I need the brake line for my truck that go's from the master cylinder to the distribution block on the frame. It is made of rubber with the metal ends crimped on it. I have tried the local parts stores and Ford dealer. None of the parts stores can get me the line and Ford says they discontinued it. Does anyone know where I can get this part, like a restoration place or obsolete parts place like Autokrafters or someone like that? Oh yeah, it is an '80 F250 2wd 351M 4speed.
Old Sep 26, 2003 | 10:46 PM
ecarter50's Avatar
ecarter50
The lines from master cylinder should be metal. The only rubber brake lines are one for each front caliper to frame and one from rear axle to frame.
Old Sep 30, 2003 | 11:13 AM
akbg's Avatar
akbg
find a junkyard that will let you pull stuff off yourself. its cheap and there is no shortage of old ford trucks. I get all my obsolete parts at the junkyard, just watch out for the wasps!
