1966 F100 Bendix power steering box
Although it doesn't work with the factory installed compressor mounts, it works just fine with the dealer installed kit made by Mapco, Ford p/n C6TZ 19B969-B with Mapco part 183-1 compressor mount and the later D1TZ 19B969-B that used Mapco part 183-1A for the compressor mount. These mounts angle the outboard end of the compressor up sufficiently to clear the fat neck of the "non a/c" pump. Below is a picture of the later 183-1A bracket which aligns the compressor sheave with the 4th sheave at the crank.
When I acquired my 1966 f100 it came with some extra parts. I have installed most of them However I have what appears to be an almost complete power steering set up. Bendix box looks new or reman. A pump couple of lines. What is this worth?. I am going to leave the old Armstrong steering in my truck.
You can reply also to my email: dgrickeycsmp@aol.com
Here is the easiest way without different engine stands, firewall bracket and shortening your steering column. Not cheap! Reman boxes are $700-800
https://www.ebay.com/itm/65-66-67-68...sAAOSw-29ZPcC3
75boogieman
04-08-2013 02:28 PM
Voodoo ChildVood
11-26-2009 06:54 PM
Bucket head
05-04-2005 05:59 AM
