EGT Gauge
Old Nov 22, 2018 | 02:36 PM
Homerunking2394's Avatar
Homerunking2394
EGT Gauge
I have gauges on the pillar for boost and exhaust temp. Was this something that came from the factory? My exhaust gauge only works when the parking lights or headlights get turned on. Is this how it is supposed to be?
Old Nov 22, 2018 | 03:08 PM
hydro man 17's Avatar
hydro man 17
I don't believe that any F-250 / 350 came with any pillar mount gauges, but I have been wrong lots of times. I guess it's called a learning curve!
Old Nov 22, 2018 | 03:15 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
No, someone installed them sometime during the life of the truck.
No, it sounds like the installed used the parking light wire as a power source instead of a 12v switched/ignition power source.
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Not factory, OE the driver side A pillar is either blank or a handle. So those gauges are aftermarket with OP assembly, which evidently ain't exactly right. Can you post up a pic or describe them? Various brands hook up differently. Typically wired in behind the light switch panel, which pops right out btw. Here's a detailed gauge install instructions from Riff Raff, lots of good pics and info.
Old Nov 22, 2018 | 03:46 PM
Colorado350's Avatar
Colorado350
THIS. ^^^^
Old Nov 22, 2018 | 08:13 PM
Homerunking2394
Old Nov 22, 2018 | 08:33 PM
Sous's Avatar
Sous
FTE Emeritus
That is NOT an EGT gauge.
This was wrong, I missed the X10 in the center of the dial.
Old Nov 22, 2018 | 08:42 PM
Homerunking2394
previous owner said he installed a sensor coming out of the turbo to measure exhaust temp
Old Nov 22, 2018 | 08:48 PM
Walleye Hunter's Avatar
Walleye Hunter
Why not?
It might be, does it work?
Old Nov 22, 2018 | 08:55 PM
Homerunking2394
Originally Posted by Walleye Hunter
Why not?
it works. It has to be egt because it goes up if I get on the throttle or am driving fast and goes down as it should
Old Nov 22, 2018 | 08:57 PM
Walleye Hunter
How high does it get? Is your PCM chipped or tuned?
Old Nov 22, 2018 | 09:09 PM
Homerunking2394
I'm currently running the pcm stock...it goes up to 700 but at cruising speed will go to 550
Old Nov 22, 2018 | 09:30 PM
Sous's Avatar
Sous
FTE Emeritus
Why not?
My apologies, I missed the X10 just under the center of the dial.
Old Nov 22, 2018 | 09:33 PM
Homerunking2394
yea that happened to me the first time I was monitoring it lol
Old Nov 22, 2018 | 10:21 PM
Wes444's Avatar
Wes444
You need to find out where the probe is installed. If it is post turbo as you say the previous owner claimed it's nearly useless. It should be installed pre turbo on the exhuast manifold to be accurate of cylinder temps. Post turbo the gases have had time/room to expand and loose temp
