Oil pan
Old Nov 21, 2018 | 03:05 PM
RandyinTN's Avatar
RandyinTN
Oil pan
Do 2019 6.2’s still have a metal oil pan?
Thanks
Old Nov 21, 2018 | 03:25 PM
MBuckholz's Avatar
MBuckholz
Yes, still metal. Hopefully the 7.X engine will keep a metal pan.
Old Nov 21, 2018 | 05:07 PM
Mkos1980's Avatar
Mkos1980
I'm new to Ford and thought it would be aluminum. Steel and salt do not mix in the northern states... Iv see seen my fair share of pans that rust through up here.
Old Nov 21, 2018 | 05:18 PM
MBuckholz's Avatar
MBuckholz
I I live in one of the top 10 snowiest cities in the US, here in Arizona, and am bummed cuz they salt here also, more frequently than when I first moved here 30 years ago. However my '11 never showed any signs of rust/corrosion on the oil pan. Should not be a problem....
Old Nov 21, 2018 | 05:20 PM
C12H24's Avatar
C12H24
Aluminum also corrodes and once it starts, it goes fast. The aluminum oxide that coats aluminum does make it more resistant to corrosion, but paint or sealers do the same for steel or iron. Steel is a better material for oil and transmission pans and differential covers. The reason is if they take a rock hit, they just dent. Aluminum will crack or knock a hole in the pan.
DISLFVR
Dec 13, 2011 09:14 AM
superduty4x4
17
Jul 30, 2008 03:13 PM
kupiec20
May 18, 2008 10:10 PM
fordv840
Dec 2, 2005 01:27 PM
