Mild 390 build advice
#62
Just curious. The Merc's 390 had two broken pistons, I replaced those with two from another matching set. These were the stock cast flat tops run with the stock cam (68 year, 2 bbl premium fuel motor) Probably had lots of 87 run through it. The other was a GT390 with the Cam Dynamics grind and forged 10 to 1 pistons, it digested anything you wanted to run through it.
#64
Yes but mercury offered a premium fuel 2bbl motor. Same flat top pistons as the 4bbl motor.
http://www.fastfairlane.com/Engines/fespechart2.html
#66
Ditto. Mine was a 68 Merc Monterey. Another I shoulda kept. 2 dr fastback. Only had 58K on the odometer when I bought it about 15 years ago. My son drove it in High School. He and his friends nicknamed it the USS Monterey. I bought a 68 Galaxie for parts about the same time. 390 2 bbl. everything in the motor was the same except the pistons.
#67
#69
The engine has been pulled, hot tanked, and completely gone through with no hidden surprises (Which is awesome) I was able to verify that it was the original 390 that came with the truck. Just waiting on the 256/262 lunati cam, should be here later this week, everything else is good to go. Dyno should be sometime next week I imagine. Ive got a few pictures of the whole ordeal so far.
Just for reference, here's how the engine looked prior to being pulled apart.
This is the truck it's going in. 1976 f100 ranger xlt 390, c6, shortbox, 4.10s with posi. ALL factory
Rear tires are 275/60/r15
#70
#75
