Smoke
Old Nov 19, 2018 | 03:47 PM
Vinford's Avatar
Vinford
Smoke
1979 F-150 4x4 with 300 -6 cyl
Battery was dead
Tried to boost it off my pickup.
Sparked like cables were on wrong but they weren't so I clipped them on.
Smoke started barreling out of solenoid on fender well beside the battery?
Old Nov 19, 2018 | 03:54 PM
caravaggio2000's Avatar
caravaggio2000
You have a short there somewhere. Inspect all the wiring from battery to solenoid and after it.
Old Nov 19, 2018 | 04:25 PM
meangreen92's Avatar
meangreen92
Could a failing alternator cause this as well?
Old Nov 19, 2018 | 09:15 PM
Vinford's Avatar
Vinford
Ill check wiring and unhook alternator , see wh
Old Nov 30, 2018 | 12:27 PM
Vinford's Avatar
Vinford
Put in a new solenoid and it will start when jumped across solenoid.
Wont start with key?
Old Nov 30, 2018 | 03:37 PM
dlburch's Avatar
dlburch
do you have voltage on the wire that is connected to the I terminal?
Old Nov 30, 2018 | 04:18 PM
User 32921's Avatar
User 32921
If it's an automatic is it ALL the way into Park?
Old Dec 2, 2018 | 11:24 PM
Vinford's Avatar
Vinford
standard transmission
Old Dec 3, 2018 | 05:49 PM
FordExplorerFanatic's Avatar
FordExplorerFanatic
Starter could be buggered. If sparks are flying like a welder then you.may have a shorted starter .
Old Dec 4, 2018 | 09:19 AM
84espy's Avatar
84espy
Regarding the battery, I have seen sparking when attaching cables to a battery that was very low on charge.
Regarding the first solenoid: How old was it and how much use did you get out of it? Sometimes the connections on the inside either get worn or break, either leaving a gap for the connection or actually shorting. This may cause smoke.
Regarding the second solenoid, since you were able to jump it to work, I would check the wire going to the S pole. Do you have voltage there when you turn the key?
Suyemura1
Jul 18, 2016 10:43 AM
maribou912
32
Apr 24, 2011 01:33 PM
mugglemac
1983 - 2012 Ranger & B-Series
Mar 31, 2011 04:07 PM
69ranger250
Dec 11, 2008 12:45 PM
cmac22
Aug 30, 2005 06:25 PM
