Misfire issue
Old Nov 18, 2018 | 10:28 PM
Nick Fender's Avatar
Nick Fender
Misfire issue
Alright so I’m having a misfire in cylinder 8. I have new plugs, I’ve swapped coils, I’ve replaced the fuel pump and checked no. 27 fuse. All good so far. I’ve done a manual compression test and it’s good. I’ve done a relative compression test and it failed. I also had 2 other codes. Bank 2 rich and bank 4 weak I believe it is. I don’t remember. This was a few weeks ago. (Bought a 94 Toyota pickup 4wd and rebuilt the motor in it to be my everyday driver) but I can’t seem to figure out what’s causing the issue. And ideas?
Old Nov 19, 2018 | 05:23 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Welcome!
I had a misfire in my '04 Expedition that was so slight and so random that it wouldn't throw a code. I ended up replacing all eight coils to solve the issue. You easily could have switched one weak coil for another. Did you carefully inspect the pigtail that attaches to the coil?
Old Nov 19, 2018 | 06:30 AM
Nick Fender
Sorry forgot to mention it’s a 2011 f150 5.0 with 104k miles. And to the reply above me. Yes I’ve swapped coils around. Didn’t change the outcome.
Old Nov 20, 2018 | 09:54 AM
alloro's Avatar
alloro
New plugs can be bad. I'd start by swapping the spark plug and fuel injector with another cylinder to see if the problem moves.
USMC3521LJF
1997 - 2003 F150
Sep 17, 2017 10:05 AM
Collin Chappell
1997 - 2003 F150
Sep 7, 2017 01:46 PM
Dan Robertson
2004 - 2008 F150
Apr 8, 2017 05:12 AM
super_steve85
22
Jul 3, 2015 09:50 AM
msm7c
1997 - 2003 F150
May 7, 2005 06:11 AM
