Winter Front
Old Nov 19, 2018 | 04:42 PM
Tom N OH's Avatar
Tom N OH
Originally Posted by George C
Winter covers are a bad idea on a modern truck. Concentrated cold on a small area opening of a modern ultra thin heat exchanger can damage them. Hardly anyone needs them, unless you live in an area that may reach a high of -25 where you need a full cover. In the lower 48? Never a need.
Do you have any science to back that up, or is that just personal opinion?
Old Nov 19, 2018 | 04:45 PM
Tom N OH's Avatar
Tom N OH
Originally Posted by bushpilot
remote start doesn't help?
An idling Diesel engine makes very little heat. Diesels warm up much slower than a gasoline engine, even when driving.
Old Nov 19, 2018 | 04:53 PM
bushpilot's Avatar
bushpilot
my 2017 6.7L ramps up the idle automatically (same as my 2004 6.0L) if the temperature is below something like 40* (f)
Old Nov 19, 2018 | 05:08 PM
Tom N OH's Avatar
Tom N OH
It can idle all day long, even at an increased idle speed & at colder temps, say 30* or below & it most likely won’t get warm enough to open the thermostat.
Old Nov 19, 2018 | 06:14 PM
mhoefer's Avatar
mhoefer
I use an all season front on mine. (CloudRider is the make) When I had my 6 OH, I ran a true winter front, it was necessary because warm ups took so long with all that air going over all the heat exchangers. I do drive at times with sustained days of -25 C or less. Whilst a winter front can help with warm up it by nature prevents cooling when towing, loaded, slow moving like plowing. So a full cover is not advised. Remember, behind there is the coolant systems(2), Air to air cooler, transmission cooler and engine oil cooler. So, sustained working the truck, a flat block of all coolers, even 1/2, or with a piece cut out may be preventing as much cooling as needed when working, and could cause overheating. Monitoring temps would be very important. Engine air temp, coolant and oil temps, transmission temps if doing so.
I have noticed my truck does warm up nicely to the full operating temp without more blocking of cooling, I am still hitting full operating temp of 195 f on the coolant.
Mike
Old Nov 19, 2018 | 06:21 PM
displacement4me's Avatar
displacement4me
Exactly. I still have my remote start to run at 2x 15 minute intervals and an up fitter wired for SEIC when needed, but I can start driving and still have my oil and coolant temp fall at a stop light. I know this because it kicks my MiniMaxx off hot tuning due to low temps haha. The winterfront significantly improved temperature control and stopped the drop out.
I would not suggest using that corrugated plastic or similar against the rad or aux coolers, that’s asking for trouble. Sitting up behind the grill still gives it space for air movement while being effective, same theory as the guys running something outside the grill.
Old Nov 19, 2018 | 06:30 PM
Tom N OH's Avatar
Tom N OH
Mike
Obviously, if you're working it, especially at slow speeds, you definitely want to monitor your temps.
Agreed, on all counts. Diesel engines need to be kept at proper operating temperatures to prevent "wet stacking", or incomplete combustion that causes unburnt fuel to run down the cylinder walls & dilute your engine oil &/or be blown out the exhaust & contaminate the DPF, or drizzle out the tailpipe in extreme cases.
Old Nov 19, 2018 | 06:37 PM
George C's Avatar
George C
Science? I doubt anyone has funded a science study on this topic...possibly thinking common sense would prevail..
Is there any science to back up that a winter front is needed on a modern thermostatically controlled cooling system that is designed specifically and correctly for the application? Are small Diesel engines in your neighbors trucks failing to maintain proper running temperatures during winter and failing from wet stacking or a lack of heat? Will Ford deny a warranty claim due the failure to install a winter front? Will Ford deny a warranty claim of a blown head gasket because of a winter front overheated your engine? Yes.
To answer your question, during the advent of inter cooled engines (which will aid heat by passing supplemental heat onto the radiator), makers of class 8 air to air aftercoolers we’re having failures due to winter fronts that were mounted, but allowing air in small open snapped areas of the winter front during cold temps. Those concentrated areas were experiencing failure due to extreme temp differences in those small exposed areas subjected to open air..
If you look at old style trucks of the past needing a winter fronts, it was more due to archaic, oversized radiators cooling faster than a thermostat could maintain block heat.
its your truck, and obviously your choice, but it’s overthinking a problem that no longer exists.
Old Nov 19, 2018 | 06:55 PM
Tom N OH's Avatar
Tom N OH
Is there any science to back up that a winter front is needed on a modern thermostatically controlled cooling system that is designed specifically and correctly for the application? Are small Diesel engines in your neighbors trucks failing to maintain proper running temperatures during winter? Will Ford deny a warranty claim due the failure to install a winter front? Will Ford deny a warranty claim of a blown head gasket because of a winter front? Yeah..
To answer your question, during the advent of inter cooled engines (which pass supplemental heat onto the radiator), makers of class 8 air to air aftercoolers we’re having failures due to winter fronts that were mounted, but allowing air in small areas during cold temps. Those concentrated areas were experiencing failure due to extreme temp differences in those very small areas subjected to open air..
So, what you meant to say is that's your opinion. You have no examples of that type of failure in this type of truck or personal experience with a winter front on the same, to back up your statements.
Old Nov 19, 2018 | 07:05 PM
George C's Avatar
George C
Tom, by all means, mount s winter front.
Trust me, I really don’t care.
Old Nov 19, 2018 | 07:08 PM
Tom N OH's Avatar
Tom N OH
Tom, by all means, please, mount a winterfront.
Trust me, I really don’t care..
I did. Ran it all last winter, ran the bug screen all summer & just switched back to the winter front about a week ago. I'll let you know when the truck spontaneously vaporizes.
Old Nov 19, 2018 | 07:18 PM
George C's Avatar
George C
Yes, I read that you “love it”.
Kinda weird, but I’m considering the source.
Just trying to help.
Old Nov 1, 2019 | 07:14 AM
  #28
satz28406's Avatar
satz28406
Ok, old thread but......1st winter with the new truck with a 6.7
I see the need for a winter front as it was 20 °F this morning and it took over 30 mins of drive time before the water temp hit 200° and opened up the t'sat. At least 10 mins was at 70+ mph speeds. This include starting the truck 10 mins before I hit the road.
I'm betting that the water temp never reaches operating temps during the winter at temps below 0° hardly ever, if at all, especially in normal suburban/city traffic.
Knowing wet stacking is an issue I have no problem installing a winter front to help get the temp up faster and to keep the temp up. Yes, monitoring the water temp will be critical when to open up the winter front for additional cooling.
I've already lost nearly a 1/2 MPG with the cooler weather due to the slow heating of the engine. The MPG is only going to get worse as the avg high starts to nose dive come December/January. The avg high temp in January in the Chicago area is in the high 20's
I know my 02 7.3 would bump up the idle 300-400 RPM at certain winter conditions.
Who's running a winter front and who's do you have? Pictures would be helpful too.
Old Nov 1, 2019 | 08:24 AM
  #29
Tom N OH's Avatar
Tom N OH
I see the need for a winter front as it was 20 °F this morning and it took over 30 mins of drive time before the water temp hit 200° and opened up the t'sat. At least 10 mins was at 70+ mph speeds. This include starring the truck 10 mins before I hit the road.
As I posted earlier in this thread, I’m using the FIA winter front/bug screen combo & love it. Getting ready to switch from the screen to the winter front today. It definitely makes a huge difference in warmup time. Just driving back & forth to work unloaded, I can leave it completely closed up in temps 50* & below. Loaded/towing, you might have to open up the flaps to let it breathe a little. I had to cut small holes in both for my front camera & its washer nozzle, no issues with any fraying from that. Keeps the bugs, leaves & crap out of the radiator during the summer months, too. Money well spent, in my mind. Oh, yeah, this will be the 3rd winter with it & the truck hasn’t spontaneously combusted from using it yet.
Old Nov 1, 2019 | 12:43 PM
  #30
FONRDAY's Avatar
FONRDAY
HI Nice truck
Originally Posted by F250inPA
hello everyone.
this is my first post.
I just purchased my first Ford vehicle. A 2019 F250 Platinum crew sb. Coming from a decade of Rams
and before that 2 decades of GM's. I was wondering if there is a weather front available for the
diesel? I saw that fia makes a weather front/bug screen but it requires drilling or double sided taping
for installation. I am looking for an application that is behind the grill and temporary in nature.
Any ideas?
thanks.
You probably wont need it. Try a winter first
