stock instrument cluster Tachometer
Old Nov 20, 2018 | 07:53 AM
1986F150six's Avatar
1986F150six
Originally Posted by greyghost85
Where r the pics of your truck? I have an 86, I6,4wd,4 spd
Old Nov 20, 2018 | 07:59 AM
1986F150six
Hey look, his charge gauge is working. That is about all you will ever see out of it. You may not see that if you move your head toward the pass side.
Hmmm, you have a good eye, Franklin2. When I repainted the gauge needles, the original ammeter was damaged. This is one from another cluster. The pointer is slightly off center [to the right @ rest], as you see it. This gauge does actually function, however. When the engine is started and the key is released, the needle swings to about midway towards "C" and then progressively returns to rest @ center [plus the slight skew to the right].
It also indicates discharge if the engine is off and headlights or brake lights are on.
Old Nov 23, 2018 | 04:20 AM
firehawk618's Avatar
firehawk618
Slightly off topic. Where do you get the paint to refurbish the needles?
Old Nov 23, 2018 | 07:45 AM
greyghost85's Avatar
greyghost85
I dont know where he did, but I have seen it in the LMC catalog
Old Nov 23, 2018 | 08:08 AM
FuzzFace2's Avatar
FuzzFace2
Check out this link on information on it.
Painting Gauge Needles - Gary's Garagemahal (the Bullnose bible)
I went the easy route be it right or wrong I used Testers model paint.
Dave ----
Old Nov 23, 2018 | 09:35 AM
Jeffrey Ferrell's Avatar
Jeffrey Ferrell
I've used testers model paint in the past on other vehicles. Its enamel, and your color options Are virtually unlimited.
Old Nov 24, 2018 | 10:30 AM
firehawk618
Originally Posted by 1986F150six
This is mine while cruising [please excuse the glare]. Take a close look at the odometer [how many digits?]
THIS is the tach I want. Where did you find one with a low scale? Heavy truck?
Thanks I'll check that out.
Dave ----
Thank you.
Thanks.
Old Nov 24, 2018 | 09:16 PM
greyghost85
Wink Beautiful
That is one gorgeous truck. It looks new!
Old Nov 25, 2018 | 06:39 AM
FuzzFace2's Avatar
FuzzFace2
Thanks.
I would have liked the low scale one for my 300 six truck but I could not beat the price from a member on here. (thank you)
From what I have seen posted both the low scale tach & the extra digit odom is from a larger truck.
I think the tach may have also been used in v8 large trucks as they would not spin as high as them in pick ups.
And because the large truck would get driven more miles that is why odom.
Dave ----
Old Nov 26, 2018 | 12:29 PM
1986F150six
Thank you.
Old Nov 26, 2018 | 12:56 PM
1986F150six
On my truck [photo] the paint was supplied by WhiteGauges.net. The needles were repainted in 2016.
Amazon Amazon
Old Nov 29, 2018 | 01:24 PM
firehawk618
Scored a 6k tach today from the local pick and pull off a 1986 300ci truck.
Going to yank the diesel tach from my truck and get this one installed today.
Old Nov 29, 2018 | 05:14 PM
  #28
firehawk618
So I put the gas tach in my truck and to my surprise it didn't work. After some research and testing of the 3 wires it needs to run I determined it wasn't getting power with the key on. The red/yellow wire had nothing.
I checked all my fuses and they were all fine.
I then remembered the PO butchered some wires behind the radio to stick an aftermarket unit in.
I inspected the mess back there and found a cut red/yellow wire. Checked this wire with the key on and it had 12v when it should. Looked a little more back there and found the OTHER red/yellow it was spliced to.
Connected it and all is well.
Ford daisy chained the 12v red/yellow wire and someone clipped 1 of the wires off at the splice which is at a plug. 2 wires crimped to one pin.
ArmamentDawg
1983 - 2012 Ranger & B-Series
Dec 31, 2017 04:48 PM
Cduff
Apr 28, 2014 03:33 PM
chuckczrxoa
2004 - 2008 F150
Dec 21, 2007 10:56 PM
gimps
Bronco II
Oct 28, 2001 05:35 PM
snakecharmed
Nov 4, 2000 01:02 AM
