Led headlights for Excursion
Old Nov 12, 2018 | 09:15 PM
gvagolf's Avatar
gvagolf
I just changed out the headlights on my 91 Toyota pickup with the 5x7 led headlight (the type with several (15) Cree LED’s). My question is has anyone found a similar light for the Ex? These lights are amazing and would like to install them on the Ford too.
Thanks.
Old Nov 13, 2018 | 06:56 AM
akcooper9's Avatar
akcooper9
Thanks.
Check out this thread. There are a couple options
https://www.ford-trucks.com/forums/1...tes-led-s.html
Old Dec 3, 2018 | 06:49 PM
Flyboy1100's Avatar
Flyboy1100
not gonna lie, been looking into this for the last day or so. I have a trucklite 7" on my motorcycle and am generally happy with it.
I would be more than tempted to find the sealed beam hardware and buy some trucklites for my Excursion.
Old Dec 12, 2018 | 10:21 AM
BroncoRN's Avatar
BroncoRN
I put in clear lens headlights and LED bulbs. Works great!
Old Dec 12, 2018 | 12:59 PM
SmackDaddy's Avatar
SmackDaddy
Which ones?
Old Dec 12, 2018 | 09:02 PM
Dogdare's Avatar
Dogdare
I didn't go with LEDs, but the best change I made was installing a headlight harness that provides full power directly to the bulbs (via a relay), rather than through the headlight switch like the stock setup.
Herb
Old Dec 13, 2018 | 06:56 AM
The Guy's Avatar
The Guy
Herb
Where did you get your headlight harness?
Old Dec 13, 2018 | 08:13 AM
SmackDaddy's Avatar
SmackDaddy
Herb
What’s the benefit? Brighter?
Old Dec 13, 2018 | 08:55 AM
BroncoRN's Avatar
BroncoRN
Originally Posted by SmackDaddy
Which ones?
Headlights:
https://www.ebay.com/itm/Fits-1999-2...MAAOSwWula9buS
Bulbs (something similar to this):
Amazon Amazon
Old Dec 13, 2018 | 09:52 AM
Dogdare's Avatar
Dogdare
Daniel Stern Lighting. It is my understanding that Daniel has someone make the harness for him, and it is very high quality. That said, my only minor annoyance was that he asks for a bunch of measurements for a 'custom harness', but the harness was not made to my measurements, but it does fit. It just doesn't route the way I wanted it to route. I think the person making the harness knows what fits and just uses those measurements.
www.danielsternlighting.com
FYI, the website is not very good, but Daniel is great at responding to e-mails
Yes, definitely brighter. Not anything like adding a 50" LED lightbar, but definitely brighter.
Lastly, I am a big fan of LED lighting, I have JW Speaker LED headlights on my Bronco, but I just didn't find anything I liked when I was upgrading my Excursion lights.
Herb
Old Dec 13, 2018 | 07:00 PM
Flyboy1100's Avatar
Flyboy1100
i got my harness installed today too. real easy to make your own, digikey has relays etc for cheap, wire is cheap, can do it all for under 50 DIY.
world of difference getting the bulbs to >14v instead of barely 12.5v. factory wire looked like about 20ga, so way undersized plus all the current was routed through the switch
Old Dec 13, 2018 | 07:08 PM
DeltaV's Avatar
DeltaV
I just used my new LED headlights for the first time tonight. Wow are they amazing. Will the above relay harness fix the static I get from the radio when the lights are On? Thanks for the help
Old Dec 13, 2018 | 07:10 PM
Flyboy1100's Avatar
Flyboy1100
no.
the harness is only used to increase the voltage to the lights. i know nothing about LED lights other than the 7" trucklite i have installed in my motorcycle. I don't trust led replacement bulbs to actually put the light where it is required unless it is a true led light in an led housing
Old Dec 13, 2018 | 07:20 PM
DeltaV's Avatar
DeltaV
no.
Thank you sir, I suspected that was the case. Was hoping drawing power, essentially directly from the battery, instead of through the stock harness, would help.
Old Dec 15, 2018 | 07:32 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
The LED bulbs are awesome. Below is the link to my build thread from when I installed them. Very bright, no issues ever. And once properly aimed, they cast a very good beam pattern. similar to HID bulbs with cutoff edge. They don't blind oncoming traffic like HID does when you install into a non-HID housing
https://www.ford-trucks.com/forums/s...3&postcount=86
