ManIfold removal help
Old Nov 12, 2018 | 11:48 AM
ige1963's Avatar
ige1963
1963 ford 223 - trying to remove manifold with engine in truck. Got all bolts out and pried about 1/4 inch out of head - got some wiggle but can't get the manifold off? Any tricks or advice?
Old Nov 12, 2018 | 12:32 PM
FuzzFace2's Avatar
FuzzFace2
I am not up on that year / size motor.
Is the intake & exh. manifolds bolted together?
If so you may want to unbolt the head pipe from the manifold this way the manifolds should just pull off.
This would also work on good old plan exh. manifolds as the pipe could be holding the manifold.
Dave ----
Old Nov 12, 2018 | 01:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
See upper pic: The intake manifold is bolted to the exhaust manifold, which is very prone to cracking. If the manifold cracks, a replacement is very hard to find!
Old Nov 12, 2018 | 02:05 PM
F-ONE's Avatar
F-ONE
Did you get all of the lower bolts out?
Did you disconnect the header pipe?
Old Nov 12, 2018 | 02:33 PM
FuzzFace2's Avatar
FuzzFace2
After seeing the picture I say undo the head pipe from manifold and you have all the carb linkage undone right?
Dave ----
Old Nov 12, 2018 | 03:36 PM
F-ONE's Avatar
F-ONE
by https://www.flickr.com/photos/156406623@N02/, on Flickr
Old Nov 12, 2018 | 04:27 PM
ige1963's Avatar
ige1963
Duh!
Well, I pains me to admit but F-ONE just posted a picture of my problem. At least I had the good sense to not beat on it! It’s amazing how easy that manifold comes off when you remove ALL the bolts! Thanks gentlemen! This forum and your collective wisdom and advice is a lifesaver!
Got everything off - obviously burnt exhaust valve on one cylinder and likely bad stem seals on a couple more. The head is now at the machine shop and I’m hoping it can be rebuilt.
Brian Culver
Aug 5, 2019 08:36 AM
clem1226
Dec 29, 2013 07:02 PM
skyjacked4x4
1997 - 2003 F150
Oct 17, 2005 11:23 PM
murder4hire
1983 - 2012 Ranger & B-Series
28
Nov 25, 2003 10:06 PM
