Sponsored by: Real Truck
Steering issues
Old Nov 12, 2018 | 09:27 AM
TheWhiteBeast's Avatar
TheWhiteBeast
Steering issues
This last Saturday I went out to the mountains down the road to do some bird hunting. Upon returning I noticed that when I pulled into the parking lot of the local bar, that I was hearing a popping noise. When I went to drive home, my steering would not return to zero, I had to steer it back to zero. One side note is that some jackwagon in a Navi was coming up the road and wouldn't yield and I had to put the truck in the ditch. I didn't notice anything visibly broken underneath, though. 2002 F-350 7.3
Old Nov 12, 2018 | 09:33 AM
Mike1's Avatar
Mike1
Would be hard to tell without getting under it, but I'd bet you probably bent a tie rod at the very least..
Old Nov 12, 2018 | 10:06 AM
Colorado350's Avatar
Colorado350
Is the steering wheel straight when the wheels are?
Old Nov 12, 2018 | 10:31 AM
TheWhiteBeast
Yes. The truck slid into the ditch *** first and didn't hit hard on the front.
Old Nov 12, 2018 | 10:16 PM
droldsmorland's Avatar
droldsmorland
"One side note is that some jackwagon in a Navi was coming up the road and wouldn't yield and I had to put the truck in the ditch. I didn't notice anything visibly broken underneath, though. 2002 F-350 7.3"
Did the noise and steering problem happen before or after the accident? If after the obvious answer is something was damaged. Almost impossible to diagnose ober the internet...just educated guessing. Have it inspected before driving...safety item here.
If the steering problem occurred before the ditch meeting then start by checking the front outer U joints. Then BJs and tie rod ends etc.
How many miles on it?
Old Nov 12, 2018 | 10:57 PM
TheWhiteBeast
183k miles. Wasn't an "accident", no visible damage.
Old Nov 13, 2018 | 04:25 PM
scottscott's Avatar
scottscott
Check your front axle u joints. I'll bet one or both are bad. Now you didn't say if your truck was 2 or 4 wheel drive, so I'm guessing it is 4 wheel.
Old Nov 13, 2018 | 09:50 PM
Tanner Smith's Avatar
Tanner Smith
Check Front Ujoints, just fixed this issue on mine. Also rattled going over bumps.
Old Nov 13, 2018 | 11:04 PM
TheWhiteBeast
I noticed when I hit bumps my truck makes a sound like a plastic ball inside a milk jug from the front end.
Old Nov 14, 2018 | 08:36 PM
Tanner Smith
my front axle Ujoints rattled/clunked so loud going over bumps in town I was embarrassed. After I replaced the clunking was gone and was steering able to return after a turn. Hope you get it figured out
Old Nov 14, 2018 | 08:46 PM
Colorado350
‘After you replaced the…?
Old Nov 15, 2018 | 03:47 AM
Tanner Smith
Replaced front axle Ujoints
Old Nov 19, 2018 | 06:50 PM
TheWhiteBeast
Just an update...finally got under the truck...the steering damper is smashed nearly completely flat...that'd do it.
Kongerup
Sep 13, 2020 09:26 PM
Loftatsea
Jun 10, 2015 08:22 AM
351Cleveland C4
15
Jul 15, 2013 01:06 PM
greentree ford
Dec 7, 2012 10:44 AM
dorideher
Oct 12, 2012 06:43 AM
