Bump stops touching leaf
Old Nov 11, 2018 | 02:39 PM
F0rdF0rever's Avatar
F0rdF0rever
Hi all. Noticed today while searching for a clunking noise that my rear leaf springs are touching the bump stops, or pretty close to it.
I do have some weight in the back. I have a cap, bedslide, and maybe 200lbs of tools. Is this normal?
Im going to go snap some pics and post them.
Old Nov 11, 2018 | 02:54 PM
F0rdF0rever
Drivers side rear.
Drivers side front.
Passenger side rear.
pass side front.
Old Nov 12, 2018 | 11:41 AM
maxum96's Avatar
maxum96
Normal. My 2006 F350 looked the same. Just for the record, those are not stops. The helper spring doesn't do anything until you load weight on the truck and the ends of the leaf spring contact those which in turn causes the helper spring put pressure on the axle.
Old Nov 12, 2018 | 12:37 PM
T diesel's Avatar
T diesel
Check near the axle for broken leafs.
Old Nov 13, 2018 | 06:25 PM
Baatzy's Avatar
Baatzy
Seems normal. When I had the lift gate on the back of my truck it sat like that. Now that I've taken it off it doesn't sit on those normally.
1994 F150 2x4
1997 - 2003 F150
Apr 26, 2017 12:53 AM
turbill
Feb 11, 2012 11:10 AM
Spyderjohn
Jun 15, 2011 02:53 PM
Huntfamily53
Sep 1, 2009 08:11 AM
JesterPgh
Jul 24, 2009 06:46 PM
