decode vin please
Old Nov 11, 2018 | 09:33 AM
hello113's Avatar
hello113
decode vin please
found this old f100 on a back road
just wanted to know what it had in it
f10ck515193
wb 114 color d model f100 body a81 a trans 12
135 3800 63 no dso
thanks mike
Old Nov 11, 2018 | 12:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hello113
Found this old F100 on a back road, just wanted to know what it had in it
F10CK515193 // WB: 114 / COLOR: D / MODEL: F100 / BODY: A81 / TRANS: A / AXLE: 12 / MAX GVW LBS: 05000 / CERT NET HP: 135 / RPM: 3800 / DSO: 63
Fixed it for you...
F10 = F100 2WD
C = 292 2V
K = Kansas City MO Assembly Plant.
515193 = 1964.
114" Wheelbase.
D = Medium Turquoise.
F100 2WD, 5,000 lbs. GVWR
A81: A = Light Gray Crush Vinyl & Medium Gray Check Stripe Woven Plastic / 81 = 81B Custom Cab.
A = Ford type 3.03 3 Speed Manual all Synchromesh Transmission.
12 = Ford 9" Rear Axle / 3.89-1 / 3,300 lbs. Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
63 = Memphis TN Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Nov 11, 2018 | 06:38 PM
hello113's Avatar
hello113
thanks nd might have to see if it can be bought it has the custom cab cluster and some trim for the headliner in it bad side left side of cab and fender has a major dent also it may have a box with a good floor in it
Old Nov 22, 2018 | 02:29 PM
danno1965's Avatar
danno1965
Decide this vin
Could you please decode this vin # f11dr674446.
Fixed it for you...
F10 = F100 2WD
C = 292 2V
515193 = 1964.
114" Wheelbase.
[/left]
Old Nov 22, 2018 | 09:36 PM
NumberDummy
Originally Posted by danno1965
Could you please decode this VIN: F11DR674446.
F11 = F100 4WD
D = 352 2V
R = San Jose CA Assembly Plant.
674446 = 1965.
Old Nov 23, 2018 | 09:28 AM
danno1965's Avatar
danno1965
F11 = F100 4WD
D = 352 2V
674446 = 1965.
thank you sir
Gesellman
Mar 27, 2019 02:00 PM
mhu
May 11, 2015 03:14 AM
breedo99
Jan 28, 2014 08:40 PM
cheddar89
Mar 8, 2012 09:13 AM
kevin206
May 25, 2010 11:39 PM
