I have a 1995 Ford Bronco, 5.0 4X4
The ABS light came on and then the overdrive light started flashing.
This has also caused the speedometer to stop working.
I have taken it to a dealership and the diag. came back with rear speed sensor.
Replaced that and nothing changed?
Any suggestions??????
After the sensor was replaced was the battery disconnected for about 5-10 mintues? Certain stored codes will not clear unless the battery is disconnected long enough for that to happen.
Also after you pull the battery, let it run and drive it for 10 or 15 mins to get the computer re cal'ed and make sure everything is sound, before you need it. (as in for work or something of that nature.)
