1978 - 1996 Big Bronco
no power 86 ford bronco
Old Dec 28, 2004 | 10:04 PM
fgrubb's Avatar
fgrubb
i have a 86 ford bronco has no power change battery starter and solenoid still have no power no light or nothing can any one help it has a 5.0 in it
Old Dec 29, 2004 | 09:54 PM
Grogtronics's Avatar
Grogtronics
Your going to have to be a little more specific. what exactly is it not doing? and, what have you tried when fixing it?
Old Dec 29, 2004 | 10:53 PM
fgrubb's Avatar
fgrubb
i have no power. i have fixed the starter ,battery and allso solenoid it is all grounded when i do the cross over on the solenoid it trys to start but wont stay runing checked all fuses could it be the ignition swithch i even went back over everything i unhoooked and made sure it was done right and if it would be ignition switch how hard r they to get too and change let me know i am lost
Old Dec 30, 2004 | 06:53 PM
hukdonquack's Avatar
hukdonquack
power problem
Im currently putting a new engine in my '86. I couldnt get power to anything either when i discovered that i had put my light switch, etc connections on the wrong side of the solenoid. Make sure that your positive lead and all other leads are to the correct post and that only your starter cable is connected to its post. It made all the difference to mine getting the power. Now if i could only get it to spark/crank... see my thread for any advice anyone has.
jacobjacob86
Bronco II
Oct 27, 2011 10:12 PM
Hardcase_Ford
Bronco II
Feb 1, 2010 06:46 PM
86BroncoGuy
Aug 23, 2007 08:06 PM
Gadden
Bronco II
Nov 27, 2001 11:19 AM
Greg01
Bronco II
Oct 5, 2001 04:29 PM
