Sponsored by: Real Truck
What tools do I need
Old Sep 26, 2003 | 11:48 AM
ktmguy70's Avatar
ktmguy70
I want to greas My slip yoke, but Not sure the size of the bolts in the driveshaft, also, how do you take off thos funky clamps on the rubber boot?
Thanks!
Ron
00 Excursion limited 4x4 V-10
Old Sep 26, 2003 | 12:10 PM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
Once again, Stan Wright's (aka Eurekaboy) website comes to the rescue...
http://www.eurekaboy.com/f250/slipjoint.htm
Four 8mm bolts.
Bands remove with some twisting.
No need to remove the front band.
If you break them (accidentally or on purpose) they can be replaced with cable ties or hose clamps.
Old Sep 26, 2003 | 12:24 PM
ktmguy70's Avatar
ktmguy70
alrighty then!
Thank you Kindly for your Quick Response.
Ron
00 Excursion Limited 4x4 V-10
Old Sep 26, 2003 | 04:27 PM
99f350sd's Avatar
99f350sd
Hope you got a good socket cause I broke 3 of them.
Old Sep 29, 2003 | 06:21 AM
ktmguy70's Avatar
ktmguy70
Yea Really
I couldnt Break mine loose with a hammer// Dont know what ill try next, i didnt hava a 12 point socket, so i will go buy one and try that, or 3 as you suggest!!
Ron
Old Sep 29, 2003 | 06:30 AM
99f350sd's Avatar
99f350sd
Not those!! the rear ones 5/16 I think. The front ones are even harder to remove.
Old Sep 29, 2003 | 07:02 AM
ktmguy70's Avatar
ktmguy70
My rear ones
my rear ones are a 12 point...
Ron
Old Sep 29, 2003 | 09:15 AM
haroutd's Avatar
haroutd
Ever think about soaking the poop out of the bolts with liquid wrench or similar product for a few days? How about some heat from the good old propane plumbing torch? Just don't heat it up too much... might mess with the hardness of the bolt, and screw things up inside. Just long enough to make things warm enough for a micro expansion of the bolt... makes it much easier to remove. That's what I had to do on one of the bolts holding my shocks in when I went to replace them.
Old Sep 29, 2003 | 09:31 AM
99f350sd's Avatar
99f350sd
Wow my fronts are 12 rears are 6. Ok
Old Sep 29, 2003 | 01:14 PM
culprit2's Avatar
culprit2
For rusted up nuts and bolts there's nuttin like J.B. Blaster.... used it on exhuast manifold bolts , cross overs , and everything in between.......... works great ............. pick it up at any parts store ......
Old Sep 29, 2003 | 01:51 PM
Foneguy's Avatar
Foneguy
I secont that......... J.B. Blaster is awesome
