Testing gas gauge sending unit
Old Nov 15, 2018 | 09:10 AM
Franklin2's Avatar
Franklin2
Originally Posted by 1981 F100
A dumb question, My multimeter has several different ohms range settings, which one is used, for testing the sending units?
If your meter has a rx1 scale on most meters will read up to 100, 199, or 99 ohms. Since the highest reading you will get is around 90 ohms, the rx1 scale should work. But a older style meter with a needle works better for this type of testing.
Old Nov 15, 2018 | 02:30 PM
1981 F100's Avatar
1981 F100
I just bought a 1974 vintage Micronta multimeter yesterday, it should do nicely
Old Nov 15, 2018 | 07:49 PM
1TonBasecamp's Avatar
1TonBasecamp
Outstanding! I have two left floating around the house still. A couple of the old ones finally bit the dust. Pretty sure that it was not the meter's fault though, in either case. One had batteries leak and I don't remember what happened to the other. Probably the same thing.
Use them in good health and happiness!
Paul
TBird Larry
Aug 22, 2014 06:30 PM
bruno2
Apr 18, 2014 05:34 PM
RubenRuben
May 1, 2012 09:52 AM
fordnurse
May 8, 2011 08:12 PM
77f250400
Jan 8, 2011 11:19 AM
