HVAC control cables
Old Nov 7, 2018 | 04:25 PM
vcsmike's Avatar
vcsmike
Trailering
HVAC control cables
I recently purchased a project 76 F250 with factory installed A/C, & I'm in the process of restoring the HVAC system. The vacuum switches for temperature & mode control are both broken, & I'm ordering new ones from LMC. However, on the same page in LMC's catalog, I see something that I don't see on my truck. In addition to the cable that goes to the temperature control door, which I do have, they show a second cable that they call "Cable Assembly - Air," which I cannot find on my truck. It's item 14 on this link: Truck Parts and Truck Accessories
The mode door & the recirculating door are both vacuum controlled. So I'm not sure what this second cable is for or even if I'm supposed to have it. If any of you could provide some insight, I'd appreciate it.
Old Nov 7, 2018 | 06:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's only one cable. See 18518 at top center of pic:
D3TZ-18518-A .. A/C Regulator Cable - 1973/79 F100/350 & 1978/79 Bronco with factory installed integral A/C // 1978/79 F100/350 & Bronco with Hi/Lo Comfort Vent System / Obsolete
Old Nov 7, 2018 | 07:32 PM
vcsmike's Avatar
vcsmike
Trailering
Thank you sir.
Old Nov 8, 2018 | 09:04 AM
beartracks's Avatar
beartracks
vacuu switch assembly
I'm not sure on this but there may be a difference in the vacuum selector switch . I think something may have changed in midyear 1977. Mine doesn't operate the vacuum motor doors in proper sequence.
Old Nov 8, 2018 | 12:45 PM
NumberDummy
Originally Posted by beartracks
I'm not sure on this but there may be a difference (there isn't) in the vacuum selector valve.
D5TZ-19B888-A (replaced D3TZ-19B888-B) .. A/C Vacuum Controlled Selector Valve Assy - Includes the "kicker switch" for the A/C (Motorcraft YH-285) / Obsolete
Scott in TX
Dec 22, 2018 08:39 AM
Dannen
Jul 23, 2018 07:48 AM
joe4law
Feb 17, 2017 11:59 AM
HENDEL JR
Dec 23, 2005 01:34 PM
xuare
Feb 16, 2003 03:38 PM
