S&B intake question
Old 12-22-2018, 10:36 AM
cps's Avatar
cps
cps is offline
S&B intake question
Looking at the intake tube on the S&B it looks like it tapers down to 3" to match up to a stock turbo. I have a 4" intake tube , does anyone have a fix for this issue? Or am i seeing things.
Thanks, Roy.
Old 12-22-2018, 10:45 AM
Dan V's Avatar
Dan V
Dan V is online now
The S&B intake tubing only extends the the coupler in which the PCV vent tube is in. From that point to the turbo is OEM.
Old 12-22-2018, 11:20 AM
cps's Avatar
cps
cps is offline
ok, but my intake tube is 4" from my 6637 filter right to the turbo. How would the S&B intake tube work?
Old 12-22-2018, 11:46 AM
Dan V's Avatar
Dan V
Dan V is online now
You are going to need some parts. What are you running for a turbo? 38R or something with a ported housing?
installed a T4....so, I have some parts laying in a heap. I need to put to together a sale ad for this site.
Old 12-22-2018, 12:30 PM
cps's Avatar
cps
cps is offline
yes, i have a Rotomaster Super GTP turbo. And yes it has a ported housing.
Old 12-22-2018, 03:42 PM
Dan V's Avatar
Dan V
Dan V is online now
You can source the flexible intake tube for the 38R from RiffRaff.
https://www.riffraffdiesel.com/garrett-powermax-gtp38r-replacement-intake-tube/
Old 12-22-2018, 06:06 PM
cps's Avatar
cps
cps is offline
After further investigation, their intake tube IS 4" at the end. Just looks smaller because of it starting out larger than 4". I should have clued into where it actually mounted up to. My bad.
time to order one.
alstieg
11-27-2009 09:36 PM
F350-6
24
07-17-2009 12:00 PM
mklemin
03-04-2008 12:17 AM
John311t
05-15-2007 07:07 AM
Reave1
12-18-2006 09:03 PM
Quick Reply: S&B intake question
