Intake tube
Old May 14, 2007 | 03:25 PM
John311t's Avatar
John311t
Intake tube
Well, mine is torn at the turbo, i tried to prevent it by putting the air filter where it is now(stuck between the battery and the rad hose lol). I need to know if there is a new intake pipe i can get (like a k&n tube or something).
Thanx
Old May 14, 2007 | 03:53 PM
F250_'s Avatar
F250_
I have asked the same question before. Seems like I've read where some have used the K&N tube. The most common answer I got was to go to a big truck parts house and get a piece of 4" exhaust pipe with a 45° bend in it and cut the ends to fit your need. It would even be better than the stock intake anyway since it would be completely smooth on the inside.
Old May 14, 2007 | 04:25 PM
John311t's Avatar
John311t
I need the tube that connects to the turbo, that what i was lookin for was like the k&n tube that will go to the turbo.
Old May 14, 2007 | 04:28 PM
ron's power stroke's Avatar
ron's power stroke
i have the old K&N air box with a drop in filter still on my shelf..thought i tossed it..not sure if the tube will fit your truck though..i can measure it if you like..remember my truck is an early 99...
Old May 14, 2007 | 04:34 PM
John311t's Avatar
John311t
You have the tube that goes from the air box to the turbo? I'd be interested in it since the input at the turbo is the same size regardless of year.
Old May 14, 2007 | 04:42 PM
ron's power stroke
i just went out and looked.. it seems its a stock ford rubber hose that go's from the air box to the ccv adapter...i have the AFE stage 2 no need for the hose..it has a 4" id hole at both ends...
Old May 14, 2007 | 05:01 PM
John311t's Avatar
John311t
i need the one that is 4" on one side and like 3 or 3.5 on the other side, where the green line plugs into.
Old May 14, 2007 | 05:11 PM
F250_'s Avatar
F250_
My bad, John311t, you had stated exactly what you were looking for and I missed it. Good luck.
Old May 14, 2007 | 05:31 PM
ron's power stroke
that would be the one from the ccv to the turbo right?? that sucks..thought i could help ya out...sorry man..good luck...
Old May 14, 2007 | 06:41 PM
Ford79's Avatar
Ford79
I'll have one available in a week or so.
Old May 14, 2007 | 06:46 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I'll have one available shortly as well. PM me if you can wait for it.....TURBONETICS ON THE WAY!!
Old May 15, 2007 | 07:07 AM
shaggy25ss's Avatar
shaggy25ss
ive got one sitting on my toolbox right now.no need for it as im running ats housing and its now 4" all the way.send me a pm withg an adress and i can send it out.
