Side Tool Box key / lock
Old Nov 6, 2018 | 09:45 PM
old28's Avatar
old28
I picked up a 1971 F250 a few months ago. It has the factory passenger side small tool box with a key lock. My ignition key locks & unlocks the driver & passenger doors but will not open the tool box. I only got the one key with the truck.
Does the tool box door use a special key to unlock it? Any aftermarket suppliers sell the key? Thanks in advance for the help.
Old Nov 6, 2018 | 10:42 PM
Fordnit67's Avatar
Fordnit67
Mine does have a separate key for the toolbox. I dont know about any aftermarket keys for them.
Old Nov 6, 2018 | 11:01 PM
mrpotatohead's Avatar
mrpotatohead
Any locksmith can make a key for it for a minimal fee.
Old Nov 6, 2018 | 11:04 PM
RichS2659's Avatar
RichS2659
There are no more keys and locks available. Visit your local locksmith to unlock it and make a new key; or drill the lock yourself and go to your local hardware store for a postal lock cylinder.
Old Nov 7, 2018 | 05:34 AM
mrpotatohead
Those locks and latches are readily available. They are generic and used on many commercial body applications.
Old Nov 7, 2018 | 08:32 AM
emeraldcoupe's Avatar
emeraldcoupe
I used a file cab lock cylinder on mine. it was like $4 from lowes. fit perfect.
Old Nov 7, 2018 | 08:48 PM
old28's Avatar
old28
Well a little bit of good news, the box latch was not locked. I do not think it has been opened in years as it was almost rusted shut. I lubed it up and got it working again. As it is the painted factory paddle handle I would like to keep it as is. I can unbolt & remove the unit and take it to a locksmith to have a couple of keys made.
Any where else in the country locksmith might charge $15.00 but not in good old Southern, CA $35 - 40 was what they want. I'll keep checking around. Thanks for the replies.
Old Nov 9, 2018 | 09:07 PM
Alex from GA's Avatar
Alex from GA
Google "how to drill out a lock" and buy a cheap lock from Lowes or Home Depot. It'll save you $.
Old Nov 9, 2018 | 10:02 PM
1TonBasecamp's Avatar
1TonBasecamp
My later model ('79) uses a separate key. Four total for my truck.
One for ignition and doors. One for glovebox. One for camper shell and one for the tool box.
If it was supposed to be the same key originally, the previous owner must have changed it.
Hmm, scratch part of that. I just looked at my key ring and don't see the round headed key I thought worked on my glovebox. I must be thinking of other trucks I've had. Unless it's missing.
Haven't used the glovebox key in so long I'm forgetting too much! Gonna' have to finish it up and get back to driving it I guess.
Paul
Old Nov 9, 2018 | 10:30 PM
old28's Avatar
old28
As I can not get to the truck this week I hope the lock unit is held in place with a threaded nut that can be screwed off and the main unit will pull out. Is this correct? If it is that would be great so I can keep the original painted paddle handle latch unit and replace the keyed lock unit. Anyone have a number for the lock replacement?
Very lucky to find the door latch unlocked.
Old Nov 10, 2018 | 02:22 AM
RichS2659's Avatar
RichS2659
Take the cylinder off, and visit your local locksmith to get a key made, or it might be cheaper to get a new cylinder. Or get one from your local hardware store.
Old Nov 10, 2018 | 07:34 PM
old28's Avatar
old28
Well I was able to work on my side box lock setup today. I removed the paddle opening lever and was able to get to the key cylinder and remove it. Went to my local hardware store and purchased a new complete keyed cylinder unit. I was able to leave the original main body cylinder and install the new keyed center section. Had to make a few modification to get ever thing working right. Total cost $9.45 + two hours time & I have lots of that. Way better than $35-45 for locksmith to make new keys.
Thanks to all that replied for all the help.
Old Nov 11, 2018 | 01:27 AM
GaryKip's Avatar
GaryKip
Good to hear you got it fixed, and at a good price!
Alex from GA
Oct 1, 2018 09:47 PM
Jolly Roger Joe
Mar 6, 2016 01:03 PM
Mike in Ohio
Feb 26, 2012 01:32 PM
X36
15
Mar 31, 2008 05:33 PM
Knight70F250
Mar 10, 2005 07:32 PM
