Sponsored by: Real Truck
Truck stalling
Old Nov 6, 2018 | 05:42 PM
Hotwolves5369's Avatar
Hotwolves5369
Truck stalling
Hello all i hope i am on the right section in this forum but here goes. I have a 99 ford f350 7.3l that keeps stalling every time i turn pn the wipers. It's rained for several days. And as long as i don't leave the wipers on the truck runs perfect but if i leave them on it spiys and sputters and then stalls. Any suggestions would be a great help. Thanks in advanced
Old Nov 6, 2018 | 06:53 PM
Djosbun's Avatar
Djosbun
Sounds like you have a bad ground. High humidity is making the ‘poor’ ground a ‘bad’ ground. Locate every chassis and engine ground, remove and wire brush to make a clean metal-on-metal contact. Check condition of negative batter cable, might have heavy corrosion under the sheathing.
— Dave
Old Nov 7, 2018 | 01:10 PM
brian42's Avatar
brian42
Veteran: Navy
The windshield seals have been known to leak. Take a look at the firewall under the dash and see if you can see any moisture intrusion. I would start with the driver's side since you are having electrical issues.
Old Nov 8, 2018 | 12:36 AM
Buildingautotec's Avatar
Buildingautotec
I cant remember if theres a harness that runs near the wiper transmission, but I have seen it on several vehicles that the wiring harness that runs near the wiper trans can fall on it and eventually wear through creating the stall while using wipers
derrickmauk1003
13
Oct 6, 2014 05:34 PM
nickmobile67
Mar 29, 2006 04:26 PM
mike460
Mar 27, 2003 09:00 AM
Blake35630
Bronco II
Jan 8, 2003 06:27 PM
oldmopar
Sep 12, 2001 10:00 PM
