Power window regulators
Old Nov 6, 2018 | 10:32 AM
RA31925's Avatar
RA31925
I actually have a 1997 F-350, but there doesn't seem to be a forum area between 1996 and 1999, so I'm posting here. Same body style, at least.
I need to replace my right rear (that is, passenger side, back row) power window regulator on my crew cab truck. All I've been able to find are window regulators which say "front right" or "front left." Can I use those for the back windows, or are the parts different?
Old Nov 6, 2018 | 01:52 PM
ZombieF150's Avatar
ZombieF150
https://www.ford-trucks.com/forums/forum25/
There is the link for the 97 to 2003 trucks.
Old Nov 6, 2018 | 04:45 PM
RA31925's Avatar
RA31925
Mm... that area's description seems to indicate it is for the F-150 and F-250 light duty trucks. It probably makes no difference for the window regulators, but there still doesn't seem to be a place for the F-250 HD and F-350 trucks from 97-98.
Old Nov 6, 2018 | 06:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This forum includes 1997 F250 H/D & F350. Read the heading at the top of this page below the Bronco forum announcement.
You do not want the 1997/2003 forum. It's for F150's and 1997/98 Light Duty F250's that use the same cab and sloping snout as the F150's.
Officially, there's no 1998 F250 H/D and F350. Ford continued making the 1997 versions until the 1999 F250/350 Stupor Duty's were introduced.
You cannot use front door manual or power window regulators on the rear doors of Crew Cabs.
Old Nov 6, 2018 | 07:14 PM
RA31925's Avatar
RA31925
Thank you.
Old Nov 7, 2018 | 12:05 PM
ZombieF150's Avatar
ZombieF150
My bad then. Figured it would be closer to what you needed. I too missed the header that it included the 97 f-350 at top of the page. Sorry for any confusion.
Old Nov 7, 2018 | 06:57 PM
Scndsin's Avatar
Scndsin
...I need to replace my right rear (that is, passenger side, back row) power window regulator on my crew cab truck.
Just curious, but what leads you to this?
Description or pic maybe?
Old Nov 7, 2018 | 06:58 PM
Scndsin's Avatar
Scndsin
Hunh...
Deleted double post. First time in a long while THAT happened.
Old Nov 8, 2018 | 09:21 AM
SkunkWizard's Avatar
SkunkWizard
I found a trick to fix widow regulators
mine is a 1991 f 150 but it works for all of them
Does the window shutter up and down for a while before it quits?
Does it still make a sound when you hit the window switch?
he is the problem and you do not have to replace the whole regulator.
once the regulator is out it take about 5 minutes to do.
Replace these 3 Teflon gear plugs I have bought them on amazon for about $12.00 with the new gear.I have also found just the plugs for $4 made by Doorman
I have also used 11mm steel ball bearings
Old Nov 8, 2018 | 09:42 AM
RA31925's Avatar
RA31925
It doesn't work and the other windows do. Granted, I haven't done an exhaustive diagnosis (yet). I wanted to line up a source for a regulator in case that turns out to be the problem (instead of the switch or the motor). It's good to know that I can't use ones listed for the front doors; however, the bad news is I haven't yet found any source for regulators specifically for the rear.
Old Nov 8, 2018 | 09:44 AM
RA31925's Avatar
RA31925
Cool, thanks for the tips.
Nope, mine makes no sound at all. No current drain when you push either the button on that particular door or at the driver's door.
Most likely it's an electrical issue.
It's good news that I probably don't have to replace the regulator, since these don't seem to be easy to find.
Old Nov 8, 2018 | 12:22 PM
ifrythings's Avatar
ifrythings
More then likely it’s the wires that come out of the cab and go into the doors, they bend in a tight radius and eventually break, I had to remake both harness for my rear doors to get the locks and windows working again. Open the front doors on your truck and look at the wiring for the rear doors, mine was so bad that the wires broke out of the black covering and were sticking out broken and all green from corrosion.
Freedom35
Nov 8, 2018 11:57 AM
FordXLT1990
Oct 27, 2018 02:52 PM
bpimm
Oct 13, 2017 08:51 PM
YooperUno
Nov 11, 2014 11:47 AM
CrewCabCOE
Oct 5, 2012 10:16 AM
