7.3 running weird
Old Nov 6, 2018 | 09:47 AM
jethrodean's Avatar
jethrodean
7.3 running weird
Hey guys. Ive only put about 6000 miles on my truck. My problem just started yesterday. When i start my truck ot idles great. Let it warm up a bit then hit the highway to work. When im shifting through the gears if i leave it a rpm for a few seconds the truck loses power bogs down. When i push the pedal to the floor it goes away. I sethe cruise at 70 and itll do it. Bog down and make a hissing sound. Fights with itself to stay at that speed. It doesn't blow black smoke. So i dont think its a boost leak. Did change the oil and fuel filter almost 2000 miles ago. Any advice would be great. Thanks fte.
Old Nov 6, 2018 | 09:48 AM
jethrodean's Avatar
jethrodean
Forgot to mention. The truck runs fine once the needle hits the o and up on the coolant gauge.
Old Nov 6, 2018 | 10:02 AM
knottyrope's Avatar
knottyrope
oil level ok?
more than 1/4 tank of fuel?
fuel pressure?
when was last time you changed CPS?
Old Nov 6, 2018 | 01:29 PM
Hussler's Avatar
Hussler
Exhaust Back Pressure valve (EBPV) is closing trying to warm up the truck quicker. This is normal but concerning if not expecting it. The hissing sound is the valve closing with exhaust rushing past it. Once engine oil temperature is up, 175 degrees on my 97 the PCM no longer commands the function. This usually only occurs on cold mornings probably around ~32 degrees or below.
Believe it or not the function does really help warm up the engine quicker but can be a bit of a pain. Most just disable the function by unplugging the two wire connector just in front and below the turbo. That will disable the valve and it doesn't hurt anything. I ran it disconnected for awhile but reconnected it because it didn't cause me any concern.
Hint: If you run the truck a bit until EOT is 135 degrees or above then turn the engine OFF then ON the function is disabled. PCM uses EOT, AIT and power demand to determine when to actuated - de-actuated the valve The temperatures posted vary by year of truck and are for my 97.
Old Nov 6, 2018 | 04:08 PM
fordpride's Avatar
fordpride
What Jim said ^^^^^^^^^
Old Nov 6, 2018 | 04:16 PM
fordman67's Avatar
fordman67
What they both said.
Kiss method engauge lol
Old Nov 6, 2018 | 06:28 PM
jethrodean's Avatar
jethrodean
You guys are awesome. This is my first 7.3. 94.5. Love this truck more than my 2014 psd.
Old Nov 6, 2018 | 06:35 PM
fordpride's Avatar
fordpride
Also if you have a faulty thermostat (stuck open) it may never get to operating temperature in the winter.
Old Nov 7, 2018 | 01:43 PM
Hussler's Avatar
Hussler
Oh so true ...
OP: Even with a good thermostat it is hard to get the temps up in cold winter mornings, unless working the truck. Guess that's why Ford developed the EBPV system. The problem with the design is if you need immediate power to get out of a situation and the valve is closed some % wise it may takes a few seconds to recover (open fully) because it's controlled by engine oil pressure hydraulically. A slow moving valve indeed.
sonofdixie
18
Apr 11, 2015 06:37 AM
Dean88
Feb 21, 2012 12:25 AM
DslWeed
Nov 28, 2010 09:25 AM
Highmark18
Nov 29, 2006 11:43 PM
JMarinos
Dec 31, 2003 08:02 PM
