Flat tow an 1986 E350 camper?
Pretty convoluted thread.
Looked to me like the discussion was about flat towing with the driveshaft pulled and rear axle assembly intact. In which case, everything inside would still be spinning and lubrication would not be an issue. It doesn't make any sense to me to take the axles out just to tow it.....
And to your earlier post, yes, everything else in the axle is spinning and there's no issue... if the axle shafts were not pulled. But my post was addressing what if you pull the axle shafts.
What we're all saying is "don't pull the axle shafts."
Thanks everyone for their input. Guy was going to trailer it but said he’d flat tow it. I was concerned he was going to do so fairly quick. So wanted to know if it would cause damage.
It’s 1k for the RV (with 40k miles on it and new tires) and the delivery.
If it happens, which I’m beginning to doubt.
I've 'flat towed' (on four wheels, with a towbar) a lot of vehicles thousands of miles (Air-cooled VW's, Toyota Mr2 5spd, Suzuki Samurai 5spd). Nothing with an automatic, but everything I've read says to not tow with an auto more than 45mph across town, because of the internal oil pump not being backdriven by the output shaft, needing the engine to turn in order to pump oil to the spinning internal parts.
Leaking oil: I'm not certain about the Ford C6 automatic, but with a non-flanged output shaft transmission used on most early American V8's, once you remove the driveshaft from the transmission's tailshaft housing (the driveshaft just slides out), the tailshaft leaks transmission fluid.
Something to check out before flat towing.
But I will repeat don't flat tow ANY vehicle without first disconnecting the driveshaft!!
WalterRoad
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-02-2013 07:05 PM
lasitter
07-20-2011 08:16 PM
jr27
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
23
04-19-2007 08:14 PM
GeneStoner
19
03-15-2005 07:52 PM
