Vacuum secondary question
My problem is the vacuum secondary spring(s). I've used all of them, including the so called lightest one, and still experience slow opening of the secondaries under hard acceleration when I know the engine is ready for more carb. With my relatively low engine vacuum, I'd think it would be the opposite. Holley's tech line still hasn't gotten back to me.
Any suggestions appreciated.
While I may not be able to help you directly with your problem maybe this will help for you to figure out your problem.
The way I understand it, you can't use manifold vacuum numbers when trying to figure out vacuum secondary opening points. For the secondaries to open the velocity of the air flow in the primary ventures create a vacuum at a metered port in the primary. This vacuum signal is routed to the diaphragm and starts the vacuum secondary diaphragm to collapse thus opening the secondary throttle plates. This occurs when the vac signal overcomes the strength of the diaphragm spring. So, it is the "speed" of the air flow in the primaries that open secondaries, not manifold vacuum directly.
To support this: if I am in 4th gear and putting along at say 15mph and floor the gas, I will have near 0 manifold pressure but also low air velocity in the primaries(because I am putting along in 4th) and no opening of the secondarie's until the RPM's come up alittle. Then the secondaries will start to open. If this delay was not there then the engine would bog and flood.
Are you using the quick change cover on the diaphragm? Reason I ask is because if your not and you are making lots of spring changes that diaphragm is VERY easy to tear. Thus causing a vacuum leak at the diaphragm and would result in your problem. In fact this is what it sounds like to me is the problem. A vacuum leak. Even if you are using the quick change cover I would look for a vacuum leak all around that housing. This is going to be easier said than done as you can't just spray carb cleaner around it like you would normally do due to the fact that the vac signal is not there at idle. I have tested them before by removing the diaphragm assembly from the carb body, then compress the plunger rod underneath it. With the plunger compressed cover the port on the side with your thumb and release the plunger. The diaphragm should stay compressed. If the plunger slowly comes back out, you have a leak.
Sorry this is so such a long post and good luck,
A 460 @ 100% VE can only use 425 cfm @ 3200rpm. 1/2 of 870=435. You are only needing the front barrels until around 3000 rpm anyway so they really do not need to open any sooner.
you will have to turn about 6600rpm to use 870cfm.
Jimmy
Jimmy
