460 Stalled Sputtering
Old Nov 5, 2018 | 10:02 AM
fishfreak101's Avatar
fishfreak101
After 3 months finally got my 94' F-250 460 e4od 4x4 back from the shop after putting a scrapyard engine in. It ran great for only about 2 days, then when I was warming it up it stalled, and now it shakes like crazy and stalls out like it is running on 4 cylinders. When I Spray starting fluid down the intake it makes the engine stall. The fuel filter is not clogged. Any help or suggestions would be great I'd like to plow with this rig and winter is fast approaching!!!
Old Nov 5, 2018 | 02:07 PM
sandymane's Avatar
sandymane
Since they could have done or not done many things on a replacement motor, I would run codes and see what is happening. If you don't know how I can send a link. In fact here it is just in case,
This should be done even if you have no check engine light. Sandy
Old Nov 5, 2018 | 04:36 PM
fishfreak101
UPDATE- Seems that bank 2 injectors (#'s 2, 3, 6, and 7) are not firing. I tested from white ground wires on injectors to pin #59 for resistance, all were under .5 ohms of resistance. Each injector is receiving 12v of power. When the truck was fired up I tested for voltage from the ground wire on injectors to the positive terminal of the battery and I did not receive voltage. Does this mean my PCM is bad?
Old Nov 5, 2018 | 10:04 PM
vjsimone's Avatar
vjsimone
do the injectors activate when you ground the white wire with the key on ?
wtrfwl havoc
Aug 22, 2019 08:56 AM
Camh65
Bronco II
Jul 4, 2018 11:41 PM
Cryptic OBS
Apr 28, 2018 12:38 AM
alex22
Jan 8, 2016 11:59 PM
myddad
16
Feb 1, 2007 02:49 PM
