Sideways Tip/Roll Point?
Old Nov 4, 2018 | 08:16 PM
ytechie's Avatar
ytechie
This question is based entirely on curiosity. The FX4 model Super Duty has a gyroscope in it, so it nows the pitch and yaw angles. Basically, now tipped it is front-to-back and side-to-side.
At what point would the truck roll over sideways? Obviously there are lots of factors based on options, passengers, etc. Let's assume it's empty. Is there any actual data available? Are there any videos of one of these rolling while driving on the side of a hill?
Old Nov 4, 2018 | 08:26 PM
PentaPop's Avatar
PentaPop
I think even the non-FX4 trucks have that screen. My plain jane XLT does. Not sure about the sidehill rollover angle but I know Paccar (parent company of Perterbilt, KW and others) has a tilt table at their R&D facility where they loosely strap the semis down and then experiment with different loads and see when they roll. Maybe the pickup makers have a similar setup but I don’t know how you’d go about finding the data. I’m not volunteering my truck to test it!
Old Nov 4, 2018 | 08:43 PM
Clubwagon's Avatar
Clubwagon
If the truck is static (sitting still) it will roll over when leaning to one side far enough that the center of gravity is outside of the contact patch of the low side tires. The key here is knowing where the center of gravity is.
Old Nov 4, 2018 | 09:40 PM
FlyinAg's Avatar
FlyinAg
It's not yaw angle it's roll
Old Nov 4, 2018 | 10:04 PM
brandon4's Avatar
brandon4
I just went out and tried this. 4 degrees as it turns out.
Just dumped my truck in the ditch.
Old Nov 4, 2018 | 10:26 PM
PentaPop's Avatar
PentaPop
C’mon now! Is that a typo? My driveway is more than 4 degrees. Did you seriously roll your rig into the ditch? Hope everyone is unscathed!
Old Nov 4, 2018 | 10:29 PM
FlyinAg's Avatar
FlyinAg
Haha I think he's joking...
Old Nov 5, 2018 | 04:46 AM
night9's Avatar
night9
Not sure on the 250 but when I went to Raptor Assault I was pretty impressed with the yaw capability.
Old Nov 5, 2018 | 04:54 AM
2009kr's Avatar
2009kr
I agree.
Ignoring width change due to tire deflection, it's just a geometry problem. If the truck is 80" wide and the cg is 40" high (just an example, I don't know the cg), it'll tip at 45*. If the cg was 30" high, it'd tip at 60*. You'd have to have some great traction to not slide sideways though.
It's a little more complicated for a dually, because the width isn't the same in the front in back. Suffice it to say, a F350 DRW can lean further than a SRW, and a F450 can lean even a little further than that (wider front).
Old Nov 5, 2018 | 07:57 AM
Turbo Dog's Avatar
Turbo Dog
I regularly pull off a road where that guage reads 8 degrees of side tilt, I get out of and back into the truck without any problems but it does seem like a fairly steep lean. No lift kit in a factory stock 2019 F250 Lariat FX4 gasser.
Old Nov 5, 2018 | 10:04 AM
troverman's Avatar
troverman
There are a lot of factors that complicate this from being a straight math problem. One is tire squish, one is suspension squish, and another is the amount of fuel you have. Wheelbase is probably another. Suffice to say that most drivers are incredibly uncomfortable and stop driving in sidehill situations long before there is any real threat to the vehicle tipping over.
Old Nov 5, 2018 | 10:44 AM
Clubwagon's Avatar
Clubwagon
Still a geometry problem. You just acknowledged a bunch of variables.
Old Nov 5, 2018 | 12:06 PM
First Dually's Avatar
First Dually
Originally Posted by troverman
... One is tire squish, one is suspension squish, and another is ...
Squish is very serious problem and not to be taken likely. I get checked by my doctor at every annual physical.
Old Nov 5, 2018 | 01:28 PM
troverman's Avatar
troverman
You like my scientific terms? Haha.
Old Nov 5, 2018 | 02:03 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
This right here. I've been four wheeling enough to know that my b-hole will take a chunk out of the seat before I roll. And you won't catch me anywhere near that in my SD!
At at least with the SD's aluminum body and beefier chassis now, the CG should be a little lower than previous gens (assuming the same height)
