Found a small leak on the degas bottle. If that is correct term for the plastic that you add coolant to. No big deal but it's hunting season and I need use of my truck.
Normally I'd order from Riff raff or similar place. Can I get one from local auto parts store, pros and cons? Do I need one from Ford , what options?
thanks Joe
If it has a leak, then I assume that it is not holding pressure for the coolant system. I do not think that you would need a Ford sDealer one. Call the local auto stores and see if they are available. I see online that they go for around 45.00. If you have a good cap, keep it for if needed later.
Goin off of what Brother Les mentioned, especially the cap. Im rock'n an auto store res. Installed it with the cap that came with. Next day, 40 miles later, while waiting in parking lot, for shiats i checked bottle. Sure enough, cap off and wedged between battery. Just so happened to have the oem in doir. Installed IT and thru the aftermarket in the glovebox. Benn good since..20k/1yr later
It’s most likely the seam, drain the Degas bottle and clean up the seam. Buy yourself a plastic welding kit, I bought the one in the link I’ll provide from Walmart. I welded the entire seam with it on my new bottle from Clay, it’s been over a year now without issue. You can have yours fixed in an hour.
Another option would be a Permatex radiator repair kit, it's a special epoxy along with some fiberglass to make a really strong patch. I've only used it once and it held up very well.
