1978 - 1996 Big Bronco
89 Bronco Stalling
Old Sep 26, 2003 | 12:56 AM
Lawzilla's Avatar
Lawzilla
Question 89 Bronco Stalling
89 Bronco XLT, 5.0. Auto Trans. Has a tendency to stall out for no reason, Hot or Cold. AC is not working, so should no tbe a probelm and not in use. Replaced the distributor pick up coil and problem seemed to go away for about 3 weeks and then came back. Replaced the throttle position Sensor and EGR valve/sensor. Can't remember what the name of this part is, but replace the small grey box attached to the left side of the distributor(facing front of engin). Replacing Pcv valve today! Any other ideas!!
Any suggestions??
Lawrence
lzilla2003(No Email Addresses In Posts!)
