I hv a 2000 f150 4.2 2wd standard cab manual trans with 321,000 I put a new self adjusting clutch, flywheel, pressure plate, slave cylinder and a throw out bearing on it 6 wks ago. The clutch adjusted great, but I hv a bounce or shutter you mite say when I take off in first and reverse and feels like it's gonna fall apart. No other gear does this. Can anyone help me with this issue.
Something wrong with the combination you installed.
Only thing you can do is replace them again with parts from another source or take a chance a second time with replacements.
Go bac, to the vendor and mfger ,with the issue.
It's a grabbing issue you likely can't ID and replace a single part with and be sure for all the labor involved.
Good luck.
