I just ordered my first travel trailer and the dealer started asking me about what my 2003 F250's receiver hitch was rated for. I mainly purchased this truck to haul heavy loads of firewood with the intention of maybe towing in the future so I had never actually checked the rating of the factory receiver. I was shocked when I saw it's only rated for 5000/500! I guess it's my fault for just assuming a heavy duty truck would come with a hitch rated for more than my previous Tacoma without needing a weight distributing hitch.
The trailer I ordered comes in at 4,999 GVWR with a 470lb dry tongue weight. This puts it at the limit of what the factory receiver will carry without a weight distributing hitch. So now I'm faced with a dilemma: do I pay $500 for a good weight distributing hitch with sway control, or do I spend $200 on an upgraded receiver that will carry 8000/800 without needing a special hitch? Having never towed more than some basic, small equipment trailers and branch chippers, I don't know what to expect from towing a 5,000lb single axle travel trailer. Any input would be appreciated.
I put a Class 5 hitch on my Dually after I noticed damage on it from a PO. I picked it up for $100 New of CL. If you’re willing to do some research, owners going from a box bed to a flatbed often sell their hitches very cheap. Call some heavy truck shops see if they have any take off hitches for cheap. Your WDH is not meant to make up for short falls with your hitch, just because I have a Class 5 hitch doesn’t mean I can run a heavy trailer without a WDH. Honestly, you’ll be able to find both on CL for a fraction of new, people spend money on campers then realize it’s not for them. They sell their stuff for cheap…
EDIT: If you do get a Class 5 receiver, you’ll need to drill the frame holes bigger. Just buy a quality Step Bit that goes up to 3/4”, it’ll cut through the frame like butter.
I installed a factory Class V 2-1/2" receiver from a newer Superduty...can't remember what year, but probably 2005-8 era. I found it local and cheap years ago. I seem to recall it was a little thicker metal but the attaching bolts were definitely larger. It has many options up to 15,000 lbs. I think the newer after market 2-1/2" Class V units go up to 20,000 lbs. now.
The factory hitch should be just fine towing that. Lots of people tow much more weight than that on the factory hitch without a WDH. If you get a travel trailer much bigger than that, it's a good idea to use a WDH with sway control no matter what the hitch is rated for.
If you are going to upgrade your hitch, I got this off Amazon for about $200. I don't think you'll overload one of these.
