Had a nice day off yesterday getting stuff done. Had a minor water leak in the bsmt. I thought it was coming from the pressure tank by the water trail but turns out it was furnace condensation line was plugged. I determined that AFTER I unhooked the pressure tank and pipe doped the fittings. Changed oil in the Ranger twice! Helps if you read the oil container! 20w50 is NOT the same as 2w50. Must be getting old.
