I took my 2017 F150 4x4 into to the dealership for its first oil change/service. I have been experiencing a towing issue with the “TRAILER DISCONNECT” message popping up about every two minutes on a 60-mile run. Gets just a bit annoying after the 60th time of going off. The dealership claims the problem is in the trailer not the truck. OK I will rewire the trailer and hardwire it all the way to the plug. I wanted a new trailer plug, but they would not install it because they didn’t think it needed it. DUH?
The other problem the came up after the service my mileage dropped from 18 MPG to 12 MPG. WHAT The $%^&? Anyone have any ideas why the mileage would drop? I am not driving around in 4-by mode nor am in in any gear besides drive.
Re. “TRAILER DISCONNECT”:
If the trailer wiring was shorting to ground you would be popping fuses, so look for an open. The trailer wires could be loose inside the plug, start with the ground wire, check both ends and the wire run. If the ground opens your Ford will 'think' the entire trailer has gone AWOL.
You need to give us some more info on your truck (Screw, Long/short bed, Engine size, speed when trailering, Mileage, etc) and the manufacture and size of your trailer would help ?
Many times, all this additional info is helpful....but I don't know how it would help address the OP's concerns.
How would the forum's help be different for either of his issues on a 2017 4x4 whether it was an X (Screw, long bed, 3.5EB, trailering at 40 mph, 10,000 miles) VS an XYZ (single cab, short bed, 3.3NA, trailering at 55 mph, 30,000 miles)??
Are certain size trailers or brands of trailers known for having frequently faulty wiring? I would think the age of the trailer may be useful to determine if where the OP lives may have caused corrosion issues (1 year old and in the desert VS 20 years old in Michigan).
It is an extra cab. driving 65 on the interstate with a trailer that is 4 years old the wiring was redone 6 months ago when I put on a new pig tail and everything was triple checked. The issue is with the plug on the truck they have been know to be corroded on the inside and it needs to be replaced.
I am more concerned with the mileage drop from 18 mpg on the highway withOUT the trailer to 12 MPG.
What are you towing. My 2013 Eco max-tow went from 17 to 12 when towing a 20' enclosed car trailer and my new 18 5.0 went to 12 also on the same towing trip.. My 04 250 diesel was the same. I climb the same 4000 pass from sea level. The 13 seemed to have more power but the 18's trans gear selection was a lot better.
The OP is saying his mpg dropped to 12 after the service....without a trailer. So he’s saying that he is getting 12 mpg when he is not towing.
I cant think of anything they could do to cause it during a regular service.
If you put an OBD II (ELM or whatever) on it, you should be able to look at the fuel trim. I'm going to bet it's way off because of some other issue. I'm surprised it's not throwing codes.
Just curious but did the dealer reset the trip data? Sometimes they do when resetting the OLM and instead of showing the 18 its has restarted the lifetime data count.
1. Check your oil level (follow the recommendations from your Owner's Manual on proper method) -- It has been discussed that the dealer will not add the proper amount or actually overfill the level.
2. Check your air filter and assembly to make sure they installed it correctly -- It is my understanding that they will at least look/inspect the air filter during the service.
3. Check tires are properly inflated
4. Check paperwork from dealership -- Did they take an opportunity to "UPDATE" your PCM/ECU with a new flash? If yes, then your truck will take time to relearn the fuel management process.
One variable could be that you are now using Winterized fuel. Now, your mpg's shouldn't drop that much...IMHO, but ??
