Sponsored by: Real Truck
Headlight issues
Old Oct 30, 2018 | 09:10 PM
Vinford's Avatar
Vinford
Headlight issues
2010 F-350 XLT gas
Headlight go out when switched to hi beam?
Everything else seems to work normal.
Hi bean indicator works but no headlights?
anyone got any ideas where to start?
Old Oct 30, 2018 | 10:01 PM
Thomas Savory's Avatar
Thomas Savory
Originally Posted by Vinford
2010 F-350 XLT gas
check passages fuse box #23 For starters.
Old Oct 30, 2018 | 10:31 PM
Colorado350's Avatar
Colorado350
Are they bulbs or LED’s? If they’re bulbs they could both be bad…
Old Oct 31, 2018 | 09:46 AM
Vinford's Avatar
Vinford
I was thinking maybe both went dead at same time.
Thanks guys
Old Oct 31, 2018 | 01:02 PM
Batman7777's Avatar
Batman7777
There must be a relay when switching to high beams that shut off fog lamps. Maybe it is faulty. As a test, make sure fog lamps are off when switching from low beam to high beam. Also, try just pulling back (Flashing,,,or pushing forward,, Don't remember) on high beam and not clicking to engage.
Old Oct 31, 2018 | 09:48 PM
Vinford's Avatar
Vinford
You called it thank you …………………………..
How about the light in the radio , any ideas?
Old Oct 31, 2018 | 10:26 PM
Colorado350
Do your dash lights dim? First thought is dimmer switch…
Old Oct 31, 2018 | 10:27 PM
Vinford's Avatar
Vinford
Everything works good and is bright other than radio lights/
Old Oct 31, 2018 | 10:29 PM
Colorado350
Stock radio or aftermarket?
Shawn_Laughlin
Paint & Bodywork
Oct 11, 2019 11:15 AM
Turbostixxx
Feb 5, 2015 06:14 AM
BroncoBoss351
1978 - 1996 Big Bronco
Sep 29, 2006 06:01 PM
VatoLoco
Aftermarket Products
20
Mar 31, 2005 10:12 AM
grafekie
1997 - 2003 F150
Nov 5, 2004 06:34 PM
