rubber seals around the trim shrinking
From what I have seen is the builders put screws into the "ends" of the trim to hold it in place. Over the years it shrunk so much that it has torn itself out of the screws and started coming out of the groove. When I replaced I removed the end screws and replaced with stainless...the heads on the stainless screws are a bit wider so it "should" stay put longer. I also covered them with pliable caulk.
I think that all the trim pieces I've replaced always had a screw at each end. (I've done complete replacements on two 5ers) Ends on the top were usually arranged so that the screw was hidden under a trim piece and the bottom ends folded underneath the camper then screwed in.
The first campers' trim was brittle and had holes in several places, the second was still flexible but had problems similar to yours, both were discolored somewhat, so new trim freshened up the looks.
Received 6,693 Likes
on
AZRRC
02-16-2014 09:25 AM
gumshoe
09-22-2013 02:53 PM
KiwiFord
06-10-2010 07:35 AM
