351c Camshaft advice
Old 10-29-2018, 09:15 PM
baddad457's Avatar
baddad457
baddad457 is offline
Originally Posted by Destroked 450
351W oem roller lifters will work in a 351C, two holes need to be drilled and taped to hold the spider in place.
Summit Racing has Ford Performance lifters, spider and bones for around $175, using these is a big savings over buying aftermarket retro lifters and links.
You'll still need to select a cam and will also need a bronze dist gear or one of Cranes special gears.
Any aftermarket cam will require matching springs no matter if it's flat tappet or roller.
He'll need a reduced base circle cam to use the O.E roller lifters. They're too tall to use with a std base circle cam in the stock lifter bores.
Old 10-30-2018, 04:04 AM
Crop Duster's Avatar
Crop Duster
Crop Duster is offline
351C
Originally Posted by 77custom408
Hello everyone I’m looking for some camshaft advice for my combo I’m putting together, I have a 1979 F-100 swb truck that I’m wanting to turn into a weekend cruiser/street truck and right now my truck has a 300i6 with a 3.03 3spd trans and a Dana 44 rear with 2.75 gears.
my initial goal was to put my F4TE roller block 351w with AFR 185 heads, scat crank and rods, roller cam, eddy air gap and Holley SA carb in it but I think I’m gonna save that for another project.
my goal now is to build a budget motor with my 351c I have laying around and my specs will be
-1971 351c engine block bored .30 over
- stock crank and rods with ARP bolts
-1971 4v cc heads with screw in studs, roller rockers
-Edelbrock performer intake
-Holley 670cfm Street Avenger carb
-pistons not sure yet looking for a streetable compression ratio don’t mind using premium fuel
I will be putting my 4spd toploader behind this motor and a 9’ rear not sure of gears yet.
the 2 cams I’m looking at are the Comp Magnum 270h and the comp XE262h and I’m wanting to know which cam would better serve my pourpose for my combo any experience or advice would be appreciated thanks
I'll throw my 2 cents in here. Been fooling with these 351C's on an off for 25 years. I'm assuming you have 66cc heads and stock deck. As far as cast pistons go Sealed Power H555CP-.030 will be around .060 down in the hole and will be around 9.1 to 9.3-1 compression, KB177-.030 pistons will be around .007 to .009 down in the hole and will be around 10.1 to 10.3-1 compression depending on the head gasket you use. Both of these pistons are flat tops. The sealed powers weigh close to the stock ford flat top and shouldn't require rebalancing the KB's are lighter and will require the rotating assembly to be rebalanced.
As far as valve train components I don't use anything Comp makes anymore, too much made in China junk. Just my opinion.
If you use the Sealed Power pistons you can close your intake valve around 62 degrees and be fine on 91 oct. With the Keith Blacks you need to be around 67- 70 degrees. Just try to keep your dynamic compression under 8 to 1 if you want to burn pump gas.
As far as a particular cam recommendation you need to nail down what your static compression is going to be and what rpm you want to operate at then call a cam manufactures tech line. Those guys have all the calculators right at their finger tips and will give good advice. The last two engines I put together I used Howards Cams with good results the plus was I didn't have to wait an hour for someone to answer the call.
Old 10-30-2018, 08:01 AM
Destroked 450's Avatar
Destroked 450
Destroked 450 is offline
So all stock 302's and 351W's have a reduced base circle cam?
My nephew spec'd the cam and had Erson grind it, I'll have to ask him about the base circle and specs.
Old 10-30-2018, 08:34 AM
baddad457's Avatar
baddad457
No, the roller 302's and 351W's have taller lifter bores, the Clevelands never had this feature, so to drop the O.E lifter low enough in the bore for it to work in a Cleveland you need a reduced base circle cam.
Old 10-30-2018, 08:40 AM
baddad457's Avatar
baddad457
Originally Posted by Crop Duster
I'll throw my 2 cents in here. Been fooling with these 351C's on an off for 25 years. I'm assuming you have 66cc heads and stock deck. As far as cast pistons go Sealed Power H555CP-.030 will be around .060 down in the hole and will be around 9.1 to 9.3-1 compression, KB177-.030 pistons will be around .007 to .009 down in the hole and will be around 10.1 to 10.3-1 compression depending on the head gasket you use. .
Last thing you want is a piston that's .060 down the hole at TDC. It'll ping like crazy. 10 to 1 ratio ? You'll be able to run on 91-93 octane. Maybe less depending on the cam.
Old 10-30-2018, 09:45 AM
Crop Duster
They don't ping at .060 down. I've been running them in my 65 with 91 oct. In fact if you choose the right cam you could run 11-1 compression and pump gas. All that said I do have real world experience with those Sealed Powers and they are a good choice for a budget build. But like I said you need a cam that closes that intake soon enough to keep the dynamic up around 7.7-1.
Old 10-30-2018, 10:16 AM
baddad457's Avatar
baddad457
If those pistons were closer to the deck, you could still run it on 91. Try it on 87 with the piston .060 down the hole. At 9 to 1 it should run on 87 if the piston wasn't that far down. No reason you can't run 11 to 1 on pump gas. But that pump gas will be 93 octane. I'm running 10.4 to 1 on 92 octane in a 331.
PRIMERED79 SHORT BED
76
08-22-2019 09:29 PM
bbf ford
01-06-2014 05:20 PM
1966Tbird
08-11-2009 04:39 PM
DrakenFyre
11-04-2006 02:22 PM
NoAZ'68
11-24-2003 04:07 PM
Quick Reply: 351c Camshaft advice
