6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Pulling cab on 6.4
Old Oct 25, 2018 | 04:08 PM
Jeffreyreda's Avatar
Jeffreyreda
Pulling cab on 6.4
I have a leak coming from what I’m assuming is an up pipe, on my 6.4 ( loud hissing noice and blows some black smoke from behind turbo) so I need to pull my cab off. My truck has a spartan tuner and I was told that if you unplug the computer system while in the process of pulling the cab you’re going to has to re-flash the computer to get it running again after wards. I don’t feel like having to pickup towed to a dealership to do this. Just wondering if because I have a programmer I can just flash it myself and get it running?
Old Oct 25, 2018 | 04:27 PM
DieselDenny's Avatar
DieselDenny
Jeff, hold on the cab. We have guys in here that can set you up with great advice.
Pointing a finger at the leak in a picture is worth a thousand dollars!!!
On the tune end. You should be able to return it to stock with your program and not need a re flash prior to disconnect. In essence you'll just reload the tune after the repair.
Speakerfritz is a member here that regularly visits and has excellent methods for jacking the cab without total removal to access areas. Search his posts.
Denny
4EyedTurd
17
Mar 19, 2019 07:16 PM
wantaford
Aug 24, 2007 09:22 PM
Rwhistles
Sep 8, 2001 09:32 PM
