How do I wire high beams into a switch
Old Oct 24, 2018 | 06:41 PM
Zachary Noles's Avatar
Zachary Noles
My 1986 f-150 doesn’t have the high beam button and I was wondering what wire is for the high beams and how I need to do that. I know how to wire but need to know what wire it would be. There is no wire where the button is. So if anyone can help me out it would be greatly appreciated.
Old Oct 25, 2018 | 02:44 AM
FuzzFace2's Avatar
FuzzFace2
So you are saying there are no wires (3) down on the floor by the dimmer switch?
Maybe someone unplugged it and tucked it up behind the dash?
Any way here how it works. (Don't know wire colors)
You have 1 wire from the main head light switch that is hot when head lights are on.
You then have 2 wires out to the head lights, 1 low beam the other high beam.
The dimmer switch just switches back as forth between the 2.
You will have to find all the wires to fix this.
How does the low beams work if the dimmer switch is not wired in?
Dave - - - -
Old Oct 25, 2018 | 07:42 PM
Franklin2's Avatar
Franklin2
The wires should be on the left side of the steering column near the left kickpanel, where the floor switch is supposed to be. Any type of switch will have to handle the low beams also, there is only one wire coming from the headlamp switch for the headlamps, and the switch decides low beam or high beam.
jinxit
Mar 4, 2018 08:20 PM
Skalywag
Jul 3, 2014 08:50 PM
doug96
Electrical Systems/Wiring
Feb 6, 2005 07:41 PM
TennVic
Nov 11, 2003 02:52 PM
npaul
Jun 13, 2002 06:32 AM
