Sponsored by: Real Truck
Windshield Replacement
Old Oct 24, 2018 | 10:32 AM
Lariatstang's Avatar
Lariatstang
Just got a new truck, haven’t even made my 2nd payment yet and I picked up a nice new chip in the windshield already
i had Safelite repair it today and it’s still noticeable. I have the option to get the windshield replaced with a factory replacement. Has anyone done this before? I’m reluctant to break the factory seal on such a new truck. I could learn to live with the chip repair but it’s going to **** me off every time I look at it. I’m leaning toward getting the winshield replaced but I want to make sure it’s not going to cause any issues.
will I even be able to tell it ever happened if they replace the entire windshield?
Old Oct 24, 2018 | 11:54 AM
Evan_P's Avatar
Evan_P
That entirely depends on the technician installing the windshield. I can't say they are all good, but every windshield I have had done through Safelite has been excellent. No signs anything was ever done.
Old Oct 24, 2018 | 01:39 PM
Djosbun's Avatar
Djosbun
I’ve had quite a few windshields replaced and never had an issue. If you have the dimpled area at the top near the rear view mirror you will want to request the new windshield to have the same. If your windshield has the ‘Super Duty’ text in that area, I don’t think any replacement will have that, though.
— Dave
Old Oct 24, 2018 | 02:49 PM
zrone90's Avatar
zrone90
My windshield says soundscreen on the it. The first time they brought me a windshield it did not have that on it. I refused it and they came back with the correct windshield.
Old Oct 24, 2018 | 03:39 PM
kgburns's Avatar
kgburns
I had mine replaced by Safelite, they had two options, one with a blue glare strip at the top, the other had a green glare strip. Both had the SuperDuty printed on them. Great job, no leaks, looks just like the original
Old Oct 24, 2018 | 04:23 PM
jav_eee's Avatar
jav_eee
I wouldn't get a new one just because of a chip. I'm probably as bad as you or worse in that I hate seeing chips and cracks but I'm waiting until I get a few more before I change it out. The one crack behind my rear view mirror gets me every time I look at it. I'm staying strong!
Old Oct 24, 2018 | 08:02 PM
droldsmorland's Avatar
droldsmorland
Keep the OEM as long as possible! I say that with all the vehicles I've owned. Factory seal is the best.
My 2011 250s replacement was a nightmare. They broke the plastic trays below the wipers, screwed up the rubber pinch weld seal the one that is above the door seal, installed the outer windshield seal improperly so the headwind would get caught under it and got black sealant on the A-pillars. Oh and the drivers side a pillar now squeaks unless I shove a pen between it and the dash. Prior to all of this which was their second attempt at a repair they tried to reseal the factory plastic border on new glass. It was loose out of the box. Seems Ford has/did have a problem with it not adhering to the glass. That caused that lovely harmonic sound everyone here has heard about when the headwind gets under the seals. My 08 had the same problem so I already knew about that drill. They replaced everything they broke after two more attempts due to wrong parts ordered. GAH! What a nightmare. I'm sure I'm in the minority and was lucky enough to find a beginner tech 3x.
What was your question again..."should I keep the factory glass and live with the chip blem" Im goin with yes. Keep it until you absolutely have to replace it.
Old Oct 25, 2018 | 06:01 AM
Lariatstang
Safelite says they will replace it with a factory replacement. It will say superduty at the top and have the “3rd visor” the only difference will be it doesn’t have the Kentucky Truck Plant sticker on the passenger side but it looks like I can get a replacement off eBay for a few bucks. They claim I won’t be able to tell it’s ever been replaced and I have requested a senior tech come do the work.
ive got an appt scheduled, still debating on cancelling it but every time I sit in my truck it just pisses me off so bad. I got nailed with a huge rock from all the dam construction in my area while driving on the interstate. It chipped through to what he referred to as the inner layer of glass so it’s really noticeable. I’ll post a pic later.
Does anyone know what the “sound screen” lettering means? I didn’t ask them if it will have that but since it’s a factory replacement with the super duty lettering I assume it will. Just wondering if I should reject it if it doesn’t
Old Oct 25, 2018 | 08:01 AM
dirthawg's Avatar
dirthawg
I've had my truck for 2 years now and I've seen and heard a few rocks bounce off the windshield. To my surprise no rock has chipped the factory glass. Aftermarket glass is not of the same quality. Be sure is says SUPER DUTY at the top, soundscreen on the lower drivers side and Carlite at the bottom center. In my opinion Carlite is the important part, they make quality glass.
I don't have an answer about the soundscreen, my theory is they add a special layer to the glass for sound dampening.
Old Oct 25, 2018 | 09:27 AM
Batman7777's Avatar
Batman7777
I have a small crack in the lower right. Safelite attempted to repair it but could not. I've been holding off replacement since the crack is so small.
I've heard ppl replacing glass and within a few weeks, another rock hits.
Auto insurance will only replace a few and then it's on you.
I called and wanted to get the OEM glass... Ford Super Duty OEM glass was quoted to me as $950.00 installed. STICKER SHOCK!!!
I haven't talk to insurance company (GEICO) yet concerning OEM replacement. Another place (Ford Dealer told me $600.00). Not sure why the discrepancy.
I really, only want the OEM glass but.... I've heard nightmare stories about after market glass.. Doesn't fit, holes, tint different color. They try to make one glass fits many...
After market glass have to meet US DOT code.. but the barely make it.. No sound insulation, no banner across the top, tint varies, thickness varies, etc etc..
Old Oct 25, 2018 | 11:06 AM
jav_eee's Avatar
jav_eee
I got quoted $285 for "factory glass" with the banner up top. INSTALLED.
Do they make aftermarket with the banner?
Old Oct 25, 2018 | 11:34 AM
dirthawg's Avatar
dirthawg
I bet they do.
Check out the dealer price for a factory windshield. $1000 windshield installed is way out of line.
https://parts.autonationfordwhitebea...wtdjgtZGllc2Vs
Old Oct 25, 2018 | 12:03 PM
jav_eee's Avatar
jav_eee
Originally Posted by dirthawg
I bet they do.
Holy hell. Almost $800 in "labor"?
Old Oct 25, 2018 | 02:46 PM
Batman7777's Avatar
Batman7777
That outrageous price came from Abra Auto Body Repair of America..
Nationwide Chain.
Old Oct 25, 2018 | 06:06 PM
super 6.8's Avatar
super 6.8
Soundscreen means it's acoustic glass for noise reduction.
