Turn signal light socket
Old Oct 23, 2018 | 12:10 PM
wb8yjf's Avatar
wb8yjf
Does anyone know where I can get a new or NOS turn signal bulb socket for the drivers side of a 76 F-100 (the one on the front of the truck) I've looked at LMC and other sites but can't seem to find one. The one I have is in poor shape and even after cleaning it with a Dremel tool, the bulb stays dim.
And good sites for good used parts for the 70's trucks?
Thanks!
Old Oct 23, 2018 | 12:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by wb8yjf
Does anyone know where I can get a new or NOS turn signal (parking lamp) bulb socket for the drivers side of a 76 F-100 (the one on the front of the truck)?
D1FZ-13234-A .. Parking Lamp and Tail Lamp (Styleside & Bronco) Socket - Right/Left is the same / Obsolete
1974 F100/350 from serial number T80,001; 1975/86 F100/350 & Econoline; 1978/86 Bronco.
1971/73 & 1976 Pinto/Bobcat (parking lamp); 1973 Torino/Mustang (parking lamp); 1975/78 LTD (parking lamp).
RPN PARTS in Erie PA has 5 = 888-864-9305.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
VINTAGE PARTS INC. in Beaver Dam WI has 20 = 877-846-8243.
Old Oct 23, 2018 | 03:01 PM
wb8yjf's Avatar
wb8yjf
Thanks Bill!
Old Oct 24, 2018 | 09:15 AM
HoustonDave's Avatar
HoustonDave
Check and clean the ground near the socket and make sure you have good 12V to the socket. Your problem may not be the socket itself. Also check that the contacts in the socket have a good connection to their wires, I have run across some where everything looks good externally but the wire to contact connection had deteriorated... could be able to fix instead of replace.
Old Oct 24, 2018 | 10:49 AM
wb8yjf's Avatar
wb8yjf
I cleaned everything really well with a Dremel tool and a brass wire brush attachment, the connections look pretty good now. I can't get to the connection where the wire meets the socket because of the way the socket is made (molded plastic) though. I suspect that might be where the problem really is, but no way to get to it w/o destroying the socket itself. I'm getting good voltage to the socket too and verified the wiring to the harness itself. I replaced the original bulbs with LED bulbs, and verified that both bulbs work great in the other (passenger side) socket too.
I have another socket on the way now.
Thanks for the input guys.
Old Oct 24, 2018 | 11:47 AM
HoustonDave
Had one I could not find a replacement for a while back - wound up using a dremel and stone to grind away the socket shell above the bad joint. Resoldered it, filled in the uncovered area with RTV and never had another problem with it. Glad you got it handled.
Old Oct 24, 2018 | 05:50 PM
samr.820's Avatar
samr.820
Had to replace the passenger's side on my 79 a few months back. I got it from NAPA for $21 I believe.
Old Oct 24, 2018 | 05:53 PM
wb8yjf's Avatar
wb8yjf
NAPA, huh? Well, that would have been a little faster. I got it from this place:
https://shop.broncograveyard.com/197...epartments/18/
I paid $14.25 for it with shipping. Should be here in a few days.
Old Oct 24, 2018 | 08:53 PM
1979rob's Avatar
1979rob
I replaced both sockets on my 78 f150 with ones i found on amazon. They were only $5 each. The fitment was a little loose in the lens so i used the foam washers from my old sockets and doubled them up on the new ones.
Old Oct 24, 2018 | 10:41 PM
wb8yjf's Avatar
wb8yjf
Just goes to show you, the innerwebs is a great place at times!
Old Oct 25, 2018 | 04:48 AM
DB429SCJ's Avatar
DB429SCJ
D1FZ-13234-A = NAPA LS6490 https://www.napaonline.com/en/p/ECHLS6490
Old Oct 25, 2018 | 11:11 AM
wb8yjf's Avatar
wb8yjf
Hopefully this thread can help others with the same issue.
Old Nov 25, 2019 | 07:26 AM
jrotten67's Avatar
jrotten67
I just came back from the junkyard...........looking for reverse light sockets for my 78. a bunch of the newer cars sockets still fit my old Fords. The sockets from a 92 F150 fit in the 78s tail light molding. So do a 96 Blazer, S-10 model. Just a thought.
Old Nov 25, 2019 | 11:49 AM
1TonBasecamp's Avatar
1TonBasecamp
Are you having to anchor them into your old housing, or do they slip fit tight enough on their own?
I've always had problems installing new sockets into old reflectors (the sockets are common) because they were always a loose fit when the old one was removed.
Paul
Old Nov 25, 2019 | 11:55 AM
NumberDummy
1974 F100/350 from serial number T80,001, 1975/79: Parking lamps and Styleside tail lamps: The lens/body is a one piece molded plastic assembly, the separate sockets twist into the lamps.
1978/79 Bronco & 1975/91 Econoline use the same lamps and sockets.
