NEED HELP WITH MISFIRE
Old Oct 21, 2018 | 06:55 PM
Serenity303's Avatar
Serenity303
Need help with misfire change the coil packs and spark plugs
Old Oct 22, 2018 | 07:36 AM
2trux's Avatar
2trux
You need to be more verbose on the nature of your problem. What are you experiencing, what are the codes, and what have you done.
Old Oct 22, 2018 | 12:28 PM
Serenity303
This is the reading
This is code
This is the reading
Old Oct 22, 2018 | 03:14 PM
2trux's Avatar
2trux
The first place to start is to swap #3 COP with #2 and see if the problem moves. If it does replace the COP, if it stays on #3 replace the plug. This is the cheapest way to start the troubleshooting.
Old Oct 22, 2018 | 03:20 PM
Serenity303
So I changed plugs and also the cop but seam to keep having issues also change cyat and it went out within a week
Old Oct 23, 2018 | 07:42 AM
2trux's Avatar
2trux
If changing the plug and COP doesn't solve the #3 misfire the next steps I would do is change the injector with another cylinder and do a compression test to see if cyl 3 is low. I would not mess with the cat until you have the misfire resolved.
Im50fast
Modular V10 (6.8l)
15
Sep 4, 2019 07:34 PM
Donebrokeit
Modular V10 (6.8l)
Apr 28, 2016 07:32 AM
Bad Bad Leroy Brown
16
Dec 6, 2015 08:50 PM
sparkplug91
2004 - 2008 F150
Dec 11, 2011 08:32 AM
