FORD F250 Automatic Windows
Old Sep 25, 2003 | 03:52 PM
Mciver75's Avatar
Mciver75
Unhappy FORD F250 Automatic Windows
I have automaic windows in my 90' F250.
Two nights ago the drivers side went down and
decided it was not going to go back up.
It is not the switch. How can i find out if it is the
window motor or not?
Dave
Old Sep 25, 2003 | 09:24 PM
NoMo's Avatar
NoMo
How hard is it to change motors with the passenger side?
Old Sep 26, 2003 | 11:17 AM
tsheriff's Avatar
tsheriff
Can you hear the motor running? If so than the worm gear is probably stripped.
Old Sep 26, 2003 | 03:09 PM
Bubba Shrimp's Avatar
Bubba Shrimp
A couple of months ago my passenger side window started making a lot a racket and going up slow. I decided it was a job for "Window Man" and took it to the local autoglass store. He replaced the gear for $45.00 and it worked okay until about a week ago when it quit all together. This time it was $103.00 to replace the motor. Moral of the story, maybe I should have replaced the whole thing to start with.
Old Sep 26, 2003 | 05:36 PM
Mciver75's Avatar
Mciver75
Thumbs up Got it fixed
Well after using a VOM meter to test eveything up to the motor
i came to the conclusion that it was the motor. Getting the motor out was a bugger. only one of the bolts was visible. So used a metal bit and drilled holes in the sheet metal where the bolts were and used a socket and spinner (screwdriver tipe handle)
to remove the last two bolts (three in all) Make sure to use a big enough bit so that the socket will fit through. Also make sure you have a magnet rod. i dropped the screws inside the door many times. Problem solved
Dave
Old Sep 26, 2003 | 05:37 PM
Mciver75's Avatar
Mciver75
PS you can usually buy a rebuilt ford motor for about $50
Dave
Old Sep 26, 2003 | 05:39 PM
kennyrrt's Avatar
kennyrrt
Grabbin' those dropped bolts is a draaaag.
Old Sep 26, 2003 | 06:43 PM
Bubba Shrimp
I congratulate you who have the patience and talent for the job. I would have using my sawsall on the door to get that motor out.
Old Sep 27, 2003 | 01:17 PM
kennyrrt's Avatar
kennyrrt
I had my BFH close at hand for my attempts. Came close to using it.
